Thread: PH Up vs Borax
    Mar 2013
    CT
    351
    PH Up vs Borax
    My Taylor test kit shows my ph is below the lowest level on the scale. The tested water has a slight brown color to it.
    What's the difference between adding PH Up (that Walmart sells) versus Borax. I'm honestly not sure where I would even find borax...
    Thanks
    Dan
    16 x 32 In-Ground vinyl, 21,000 Gallons, Hayward Cartridge Filter, Hayward Tiger Shark robotic cleaner, Taylor K-2006 Test Kit
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: PH Up vs Borax
    Walmart sells it in the laundry section. Many grocery stores do, too. It would be near the items like Oxy-Clean, etc.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: PH Up vs Borax
    pH Up contains sodium carbonate (a.k.a., washing soda or soda ash) which is more effective in raising pH vs. Borax. Therefore, to raise the pH to a given target level you would use about one-half the amount of pH Up (by weight) compared to Borax.
    Mar 2013
    CT
    351
    Re: PH Up vs Borax
    Thanks! Very helpful.
    Should I post my TA number prior to adding anything to raise the ph??? I can do a full range of tests tonight...
    Also, if the tested water is slightly brown - could that be an indication the ph reagent is going bad??
    30,421
    Re: PH Up vs Borax
    How old is it? I am not sure I can remember a pH result of "brown" being reported.
    Yes, your TA should be reported as well. What kit are you using?
    Mar 2013
    CT
    351
    Re: PH Up vs Borax
    Taylor K-2006 Test Kit. The reagent is about a year old.
    I'm going to buy a ph test strip kit at Walmart to double check. Both my wife and I agreed the color was on the brown side.
    What's weird is that my ph was about 7.2 a few weeks ago accoridng to my test kit. I verified that at the local pool store as well. Now the color doesn't even register on my test. Something must be wrong with the reagent.
    Should I clean out the large test tube with something to make sure there is no residual chemicals/reagents in there?
