Results 1 to 7 of 7
Thread: Pool cleaner walks up the wall and out of the water
    Jun 2014
    canada
    1
    I have a Hayward dv4000 cleaner, in a above ground pool. I cant seem to figure out how to get it working properly, I followed the very poor instructions, it came with some kind of valves which I have no idea what they are for. Anyway, I have no leaks, I tested the flow with the regulator, its right where its supposed to be. The cleaner works awesome, sucks up everything and moves perfect, but it just wants to go in one straight line where ever its pointed, then walked right up the wall and out of the water till it looses suction and then just sits there.
    Any help would be great!
    Thanks!
    Re: Pool cleaner walks up the wall and out of the water
    Here's a link I found to the owner's manual, which you probably already have. Couldn't find much else.
    http://www.doheny.com/Pdfs/ISDV5000.pdf
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    My cleaner was doing the same thing until I cut back on the suction on the cleaner, now it goes to the top and drops down, use to always get stuck on the light, but no more...I would try that first cut back on the suction...if you can...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Donldson's Avatar
    NW Ohio
    2,917
    Same as boston62, I switched to low power on my pump and my cleaner doesn't have the strength to climb the walls anymore. If you don't have a 2-speed pump see if there is anyplace to adjust it at the cleaner head.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Okay, now that you have some real answers, I can reply.
    Every time I see this thread title on the posts listing, it sounds like the opening line of a joke.
    Casey's Avatar
    SW PA
    10,457
    Gosh I would laugh after I cried trying to figure this one out! lol
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    What I did, I just cut back on the ball valve from opening full...
    Autopilot SWG
