Results 1 to 11 of 11
Thread: PH Not Lowering with MA
    May 2013
    Washington, Il
    40
    I've used the pool calculator to estimate the amount of MA needed to lower ph from 8.0 to 7.2 (approximately 1/2 gallon). I added a full gallon of MA and my ph has hardly dropped anything noticeable. Using the tf100 test kit. Any suggestions? Got the MA from Lowes.
    40,000 gallons (20' x 40'); IG; vinyl liner
    sand filter
    BBB method for 2 full seasons
    tf100 test kit
    central Illinois
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: PH Not Lowering with MA
    Odds are, you ended up with the half-strength low-fuming stuff. Study the label and look for the concentration. Enter the strength in the calculator.
    Be sure you set the pool volume and the TA correctly, too, because if they went to the default settings, it won't work.
    What is the strength of the acid?
    What was the TA before adding the acid and after adding the acid?
    Support the site
    Butterfly's Avatar
    South Carolina
    10,045
    Have you confirmed the strength of the MA? ie, read the label? Some is only half strength.
    You're done SLAMing when:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    I would agree, the acid is likely not 31%, but without even seeing TA, a half gallon of MA won't do much in a pool that size starting from 8.0 pH. Whether it is strength or volume (or both) you are not getting enough acid in the pool yet.
    Check the strength, double check the Pool Math cculations just to be sure. You can find full strength MA at local hardware stores usually. You might even find a local pool builder supplier willing to sell to the public. I found one, and the acid is $3.00 cheaper per gallon. Full 31.45% HCL (MA)
    Essential Links:
    May 2013
    Washington, Il
    40
    I've now used the correct amount based on strength and am still seeing only small results (not working out the way the calculator says it should). I suppose I just continue to add more muriatic? No adverse affects if I continue to equipment, etc. . . ?
    sand filter
    tf100 test kit
    central Illinois
    Richard320's Avatar
    Jan 2010
    19,071
    Quote Originally Posted by birkesl View Post
    Maybe your pool is bigger than you think it is?
    What is your TA?
    How much muriatic acid did you add?
    Support the site
    30,432
    To answer your question, there are no adverse affects. It might be worthwhile to change out your pH test block and chemistry if they are more than 6 months old.
    38,524
    Quote Originally Posted by JamesW View Post
    What is your TA?
    And what is the strength of the acid you have?
    If you would answer some of the questions that have been asked of you, we would be better able to help.
    May 2013
    Washington, Il
    40
    I'll report back soon on new test data and added MA change in effect. . .
    sand filter
    tf100 test kit
    central Illinois
