Thread: Just too easy! Thank you TFP!
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    FC 7.5
    CC 0
    TA 80
    ph 7.5
    CYA 60-70
    Water: perfectly clear!
    Soooo glad I found this place! Any adjustments that I should be concerned about?
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Mar 2014
    Las Vegas
    288
    Re: Just too easy! Thank you TFP!
    CYA is a little on the high side, but I wouldn't do anything about it, it is manageable at that level. The only other adjustment needed is your bathing suit. GET WET!!!!!!
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Butterfly's Avatar
    South Carolina
    10,045
    The CYA is a little on the high side for a non-SWG pool, but you seem to have compensated with FC
    Just be careful not to add any more CYA, and maybe let that level come down some.
    Got a pic for us?
    You're done SLAMing when:
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Great Job!
    Assuming that your pool is not a salt water pool, just keep an eye on the CYA level to make sure it does not get any higher. Also, I do not see a calcium (CH) test. At some point, I would test for that just to see where it stands. Since your water is perfectly clear along with the fact that your numbers look good, I do not see the need for any adjustments right now.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by northrn View Post
    FC 7.5
    CC 0
    TA 80
    ph 7.5
    CYA 60-70
    Yes, your number of posts is too low. Get out there and answer some easy posts!
