Results 1 to 11 of 11
Thread: How to calculate water turnover time?
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Here is the info from my pump. How do I figure out how many hours I need to turnover the water once? I had a timer installed this evening and I'm trying to decide how long I need to run my pump. I've read a lot on here and have ideas to start but have no clue how long it takes my pool to turn over the water. Can anyone explain how to figure this?
    Attachment 30497
    Thanks!
    27' Round X 54" Aqua Leader Sentinelle AGP, Vinyl J hook liner. 18,500 gal.
    Waterway 19" oval sand filter, US Motors EZBN25 1.0 hp 1.5 SPL Pump, BBB (Empty Aqua Smarte System connected, may use during vacation), Barracuda Zodiac 1500,
    Taylor FAS-DPD K-2006 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: How to calculate water turnover time?
    You'd need to measure head loss with vacuum gauges and compare it to charts to determine flow rate. Here's a simpler way: http://www.troublefreepool.com/conte...-pump-run-time
    brmommy's Avatar
    Jul 2013
    Southeast Ohio
    74
    Yes, I had read that link before I posted. I think I'm going to start at 8 hours and see what happens. I thought there was a formula to figure the turnover. Not sure where I read that.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Turnover is at best a ballpark guide to a starting point for needed filtration level, it is not in itself a goal, just a tool to give you a starting point to tune from, and a questionable one at that.
    Jun 2013
    Manitoba, Canada
    153
    We just run ours 24/7, no problems, pump is on its 3rd season.
    38,300
    Quote Originally Posted by xanadu View Post
    Well that is certainly one way to waste money.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Quote Originally Posted by brmommy View Post
    The short answer is you don't need to.
    Pump run time is generally independent of turnover despite what you read on the internet. Read the article in my signature on pump run time and the article in Pool School. Most pools only need about 3-4 hours per day. That is what I do.
    Mark
    Jul 2013
    New Jersey
    70
    Quote Originally Posted by mas985 View Post
    +1.... 4 hours seems to be the sweet spot for me too. My pool is 22'
    Jun 2013
    Manitoba, Canada
    153
    We see very little difference in our hydro bill when I compare the first summer only on 8 hours a day, and electricity is very cheap for us up here. So, not a waste to me.
    Nov 2011
    Moberly,MO
    1,010
    I have been in this business for over thirty years. The people that have the least trouble with water clarity is usually the ones that turn their pump on and let it run. They also seem to have motors that last longer. Just my .02 worth.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    mas985's Avatar
    Pleasanton, CA
    11,737
    30 years ago, FAU did a study on pump run time and wrote a report showing that 3-4 hours of run time is what most pools need (see my signature). But the days of unfettered energy use are gone. Like it or not, the industry is moving to reduced run time and lower flow rates. Many States are mandating VS or two speed pump WITH timers. Also, many on this forum, including myself, have found short run times just as effective as running 24/7 so I think this is going to be the future of pool ownership.
    Plus I bet many of those pool owners you site were using trichlor pucks. With CYA build up, they probably would need more run time just to get enough chlorine in the pool to compensate for the excess CYA. It seems to me that most of the problems people seem to solve with run time are actually chemistry issues.
    Mark
