Page 1 of 2 12 LastLast
Results 1 to 20 of 39
Thread: Jeez what went wrong
    May 2014
    Dfw
    29
    Hi there. I thought things were going good but last week I had slightly green water. I shocked pool with 2 lbs cal hypo. That was friday. I went in today with these numbers and they are calling for 12 lbs sodium bicarbonate and 2 cups an hour later of muriatic acid. I don't feel like that much muriatic is necessary. I sure could use some advice! 12500 gallon vinyl lined.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    Re: Jeez what went wrong
    Welcome!
    If you believe those results (I don't) the only things I see wrong are slightly low TA and slightly high CYA. That high FC is actually just fine for the CYA level.
    The TA can be fixed with Baking Soda. (Common name for the sodium bicarbonate they just sold you) How much depends on the size of your pool, which we don't know since you haven't filled out the signature yet. Odds are, they are overdoing the TA and then having you add acid to bring it all back. Why? The TA isn't that low, and baking soda doesn't affect pH very much, and your pH is already at the low end of swimmable.
    The high CYA level is indicative of a steady diet of trichlor pucks. For a number of reasons, we discourage them for daily use. Especially now that your level is getting quite high.
    The number one thing wrong is that you are letting the pool store test your water and sell you things you may not need. If you had your own suitable test kit and did your own testing day-to-day and added only what you determine you need, your pool would look better than you ever imagined for less money than you thought possible. It's not too late to start.
    Fill out your signature so we can help. Read our philosophy and learn our lingo. Learn about Pool Chemistry and what chemicals do what and where you can buy them cheaper. Baking Soda (That stuff they sold you today) costs about 4X as much at the pool store as at Walmart or Costco.
    If it sounds good, learn about test kits. Or just skip that article and get the best bang for the buck.
    By the way, what happened to you is a very mild case of being pool-stored. Add that phrase to your vocabulary.
    I just read the paragraph at the bottom of the test report. They actually explain why having CYA over 50ppm can be a bad thing. It looks like this might be one pool store that actually helps their customers!
    But then you look up and see an FC reading with two significant digits, and the respect starts to fade...
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What they said, Don't ever think a pool store is your friend, or has your best interest at heart above their own profit. Sure some are better and some are worse, but their primary effort is to sell you something, if not today then tomorrow.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to TFP!
    I would suggest the reading Richard outlined for you, getting your own good test kit, and taking control of this yourself.
    Judging by what they have already advised you, will keep you on a perpetual chemical addition roller coaster. We can show you how to run this much more smoothly and easily.
    Essential Links:
    May 2014
    Dfw
    29
    I did as directed. Pool is not looking clear. Small amount of green on the stairs.
    Free chlorine: 7.8
    Combined .4
    TA: 100
    CH: 290
    CYA: 70
    I used a new taylor 2006
    Sand filter running 10 psi
    12k gal pool vinyl
    90 water temp sun all day
    Richard320's Avatar
    Jan 2010
    19,031
    Quote Originally Posted by Megamix068 View Post
    Free chlorine: 7.8
    Combined .4
    TA: 100
    CH: 290
    CYA: 70
    Used taylor 2006
    12k gal pool vinyl
    The pool isn;t clear because I didn't give explicit instructions about water treatment, just convincing you that you need your opwn test kit and that the pool store is not your friend.Now that we have some decent results, we can get down to it. You need to perform the Shock Level And Maintain process.
    For 70 CYA, that means bringing the FC level up to 28 and replenishing it to keep it at 28 again and again every few hours until it passes all three tests. And thereafter, never letting it dip below 5. The alternative is to replace about a third of your water now, which will lower CYA level to 45 or so, which will lower shock level to 18 and afterwards, a minimum of 4. The payoff is that you may never have to do this again, and your water will be crystalline and sparkling well before Fourth of July.
    To get from 7 to 28 is going to take a little over 3 full jugs of 8.25% Clorox (or the equivalent in stronger liquid pool chlorine) and probably two or three times that much the remainder of the day and that much again the next day and probably more, but at a lower rate. If all you have is some green tint and a little sliminess, it could be over by the end of the weekend. A seriously green and chunky pool usually takes about two weeks, but you're not that far gone.
    So... it's your choice. Start a partial drain now and delay the SLAM process a little but save a bit of bleach, or get started tonight. You won't lose any of the bleach to sunlight overnight, so you could get a good kill going and hammer it again really early in the morning and get another big kill over before the sun really starts hitting the water. But long term, you'll be happier with a lower CYA level.
    May 2014
    Dfw
    29
    This was in my pump housing window tooAttachment 30610
    Richard320's Avatar
    Jan 2010
    19,031
    That was in the pump strainer basket? What is it? Cloth? Paper towel? Some alien life form? A piece of tripe?
    May 2014
    Dfw
    29
    Feels like cloth. Instead of BBB I'm calling my method AAA3: alien,aliens.alien3
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Quote Originally Posted by TomBorg View Post
    They also indicated that FC of 9 was high for CYA of 80. It's like they almost get it. The paragraph at the bottom even talks about "over-stabilization" and "chlorine effectiveness", but they just can't seem to put it all together. To quote the great Maxwell Smart, "Missed it by that much."
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    Richard320's Avatar
    Jan 2010
    19,031
    Better check that your skimmer basket is in place. That should have never gotten past it. Luckily, the pump strainer caught it.
    As an aside, if the skimmer basket floats around, a big rock - too big to fit down the suction pipe -- works great.
    May 2014
    Dfw
    29
    Would poolproof help ease my maintenance this summer? I only ask because everyone in my neighborhood uses it and won't shut up about it.
    Richard320's Avatar
    Jan 2010
    19,031
    Never used it, never seen it. Use the search box up above on "poolproof" and see what comes up.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Ask your friends if they like swimming in pesticides/herbicides. That is what is in "poolproof". Have them look up the MSDS, then when they have the list of ingredients, look them up.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I'd recommend going with a borate addition but that product isn't the way I'd do it. This is how I plan to do mine : http://www.troublefreepool.com/threa...ol-Why-and-How
    Another thread on the topic: http://www.troublefreepool.com/threa...ter-Harmonizer
    Then you can brag how you did the same thing for less $$$ and then instead of a 40+ buck container a year you only need to make up what you loose during backwashing or if you drain some water off .
    Solar Blanket, Well Water, Borax Added. 68
    May 2014
    Dfw
    29
    Will draining 1/3 of the water out cause any problems with the liner?
    Richard320's Avatar
    Jan 2010
    19,031
    No, it should not. As long as you leave a foot or so in the shallow end it shouldn't shift any.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    +1 and draining it now as was said will save you $$ in chlorine.
  20. Back To Top    #20
    May 2014
    Dfw
    29
    Ok drained to roughly just over 12" water left in shallow end and filled back up. Cya looks to be about 50. Now do I adjust chlorine level or add acid first to get my ph down? Fc is 7 cya 50
    Ta 100. I didn't know if I can go towards shock level and add acid at the same time.
