Results 1 to 7 of 7
Thread: Vacuum adapter for Intex Ultra Frame 22' AGP
    Jun 2014
    Lafayette, LA
    11
    Hello guys!
    I am new to the pool crew. I just put up an Intex Ultra Frame 22' AGP. I need a better vacuum system than the garden hose thing. Do you know if this adapter will screw onto the intake side of the filter pump? I dont have the skimmer and i just want to hook up a vacuum to the filter pump. its a 2500 gpm paper filter pump. It also has the plunger valves. Heres a pic of the adapter:
    If not can i just put the vacuum hose into the hole and it will stay? Sorry so many questions. Trying to learn.
    Thanks for your help!
    duckcmmndr's Avatar
    May 2014
    Arkansas
    64
    Re: Vacuum adapter for Intex Ultra Frame 22' AGP
    That fitting did screw onto my 18' Ultra Frame intake.
    I bought the Intex deluxe pool care kit for $40 that came with a hose and vacuum and am happy with the way it works.
    Intex Ultra Frame 18 X 48" AG (6,420 Gallons), Intex 16" .95HP Sand Filter SWG System (2650 GPH), Hayward thru wall Skimmer, Hard plumbed with fountain, Taylor K-2006/SpeedStir/SampleSizer
    May 2012
    Baltimore, Maryland
    183
    Welcome to TFP!
    Yes that attachment will screw on to the intake sidewall fitting. However I too bought the Intex deluxe pool maintenance kit like duckcmmdr. It included that attachment along with another attachment just like that one but of smaller diameter. That attachment is actually the attachment used for the skimmer which is also included in the deluxe kit! The kit also includes a telescoping pole, A vacuum head and body with leaf screen, A leaf net, A brush, and over 20 foot of 1" vacuum hose. The smaller diameter fitting is for the vacuum hose, I use that fitting for my skimmer.
    However!
    If you have a standard vacuum hose and pole with vacuum head that pump should allow you to just push the hose in the hole and it stay there without any fittings...... although not using a debris bag may cause you to have quick loss of suction and or pump motor issues if something were to get sucked up into your pump/filter. If you are using the newer twist style plunger valves using any vacuum may also cause the anti-suction valve to allow air into your pump and also cause you problems. There is clear plastic caps that are supposed to go over the anti suction valve on the twist style plunger to not allow air in the system. remove after vacuuming....
    Hope this helps!
    15'x4' Metal Frame Intex 3yo (2nd year winterized) 16" 2650gph intex sand filter, Thru wall skimmer, dual inlet/single outlet, 1000gph intex pump (heater) Solar Cover TF-100 testkit, TFPC
    Jun 2014
    Lafayette, LA
    11
    Thanks everyone!
    jmcdtucson's Avatar
    Jun 2014
    317
    So THAT's what that clear cap is for. Thanks!!!
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Blacklisted's Avatar
    Sep 2013
    El Cajon CA
    126
    Quote Originally Posted by theblet View Post
    Hello guys!
    Like others have said this should work for you. And I just bought a 35' vacuum hose from walmart that has a couple short pieces of the clear rubber hose to use as adapters and it works on the adapter you have pictured. If you find a hose that doesn't have adapters you can go to the hardware store with the fitting and figure out what size tubing will work for your hose.
    Intex 15'x42" Metal Frame pool 4200 GAL with Intex SWG. TF-100 test kit. Our Pool Install Thread
    In Work! Master Spas Legend Series LSI 557 3-4 person Hot Tub, 230 GAL using bromine to sanitize it. Hot Tub Install Thread
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    A month old thread now, but it was brought to my attention from another thread.
    I have a 22' (does the vacuum, skimmer, and stuff no longer come with the pool? Mine did but that was 3 years ago...) with the 2600 gph paper filter and this year I tried to vacuum the bottom when opening up by just connecting the hose to the piece shown above. Worked for about 30 seconds before I was turning the filter off, draining, cleaning not only the filter but also disconnecting the hose and cleaning the grid where the hose connects to the filter/pump.
    I gave it another go and 30 seconds the filter was plugged up again. That little netting inside the vacuum connection that goes into the skimmer really collects almost everything and with that I usually either vacuum the entire pool or only have to clean the filter once. I gave up on the 2nd time with trying to vacuum straight to the filter and left the vacuuming until we got a few more inches of rain that I could connect up the skimmer.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
