Page 1 of 6 1234 ... LastLast
Results 1 to 20 of 101
Thread: Patience!
    Patience!
    I am to tired to try and come up with a good excuse for letting my pool get this bad. So I'll just be honest and admit I was lazy The cover ripped over the winter and I just never managed to get out in the cold and work on it. So now it is a swamp.
    Last week:
    FC-0
    PH-8.0
    CYA-0
    TA-110
    BORATES-10
    Three days ago:
    cya raised to 55
    ph lowered to 7.6
    So I began shocking. My wife and I have taking turns testing and adding bleach 24 hours a day. Yes 24 hours a day. (I got stuck with the night shift lol). Our shock level is 17. We have been testing every hour, eventually 2 hours. I have had to clean my filter more times than i can count. We scooped and vac'd everything out before starting.
    My problem: 3 days and 37 gallons of 6% later it does not look any better at all. Pic is from today! Am I missing something? Any ideas? I'm wondering if it would be easier and cheaper to just drain and refill pool.
    Ron
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: Patience!
    Love the picture, can't wait to see it transform.
    A couple things: organic debris will slow you down tremendously. You need to physically remove as much as you can with the vacuum, or a leaf rake or a leaf grabber. Second, shock level is 22 for 55 CYA.
    http://www.troublefreepool.com/threa...-Drain-or-gain
    http://www.troublefreepool.com/threa...-green-monster!
    http://www.troublefreepool.com/threa...hat-my-problem
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Patience!
    Shock level for a CYA of 55 should be 24 ppm not 17 (I was rounding up to 60 ppm cya)
    Re: Patience!
    "We scooped and vac'd everything out before starting."
    If you like that pic you should have saw they pile of stinking rotting **** we scooped out. We were hauling it away in wheelbarrow loads.
    Hmm pool calc says "Shock:17 Mustard Algae Shock:32"
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Patience!
    http://www.troublefreepool.com/conte...art-slam-shock
    Shock level for a CYA of 60 is 24 Mustard Algae shock level is 35
    For the more detailed chart http://www.troublefreepool.com/threa...rine-CYA-Chart
    Richard320's Avatar
    Jan 2010
    19,046
    Re: Patience!
    Oops.
    poolmath says 22 FC for 55 CYA.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Patience!
    Ike
    p.s. also you should use the pool math link at the top of this page, pool calculator has a number of bugs and is no longer being updated
    Re: Patience!
    Ok Thanks guys. Pool Calculator shortcut replaced with POOLMATH shortcut. And I'm off to add more bleach.
    Sharkline Matrix 15' x 30' x 54" Oval, Pentair Clean & Clear 150 sq. ft. Cartridge Filter, 1-1/2 HP OptiFlo Dual speed Pump, TF-100 test kit, borates
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Patience!
    You may have started out with ammonia in that swamp and that would have taken a whole lot of chlorine to get rid of before the chlorine can even start on the algae.
    What is your fc and cc like now? How much are you going losing between tests?
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Re: Patience!
    We are checking every 3 hours now. It's dropping 3 every 3 hours. Last test Fc 14 cc 3 tc 17.
    I really thought I knew a lot about pools until this little experience. My filter got to the point where cleaning wouldn't drop the pressure back down, so I had to buy new filters. A few days ago the pump wouldn't start. Just hummed. Had to replace the capacitor. And today when we turned the pump off to clean filters it did the same thing. Capacitor is good this time though. I can spin the motor easily. So I have just been spinning the motor while hitting the power switch to get it going.
    Re: Patience!
    I think...hope...maybe...I have seen my first sign of progress. The pool looks the same but when I cleaned the filter it wasn't bright green it was more grayish black. Also I only had to clean the filter twice today. Previously I was cleaning it every 2-3 hours.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Patience!
    Quote Originally Posted by Ron69 View Post
    Yep, that sounds like real progress
    You're done SLAMing when:
    Re: Patience!
    After 4 days now of SLAMing.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Patience!
    Compare this to the photo from yesterday and you can see some progress, just hang in there, and keep your FC up where it belongs
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Re: Patience!
    It kinda looks like green jello.
    May 2013
    Bay City, Michigan
    283
    Re: Patience!
    WOW, I guess I'm surprised your only losing 3 fc every 3 hours with that big green mess. What is your fc target that you aim for when you add chlorine?
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    Re: Patience!
    It doesn't smell like green Jello!
    It really doesn't make sense to me. I would think that the fc loss would steadily decline until it held steady. At the same time the cc would steadily rise. And my filter cleanings would slowly get less frequent.
    But it hasn't worked that way at all. The fc loss is declining but not consistently. It might drop 3 one time then 6 the next, and then three again. And the cc is bouncing around from 1 to 4.5. And the filter cleanings ....at first I was cleaning filters every 20 minutes, it slowly got better until yesterday and then suddenly I'm only having to clean them twice a day. I really don't understand it.
    o yeah poolmath says shock is fc22 the chart says 24 so I.m doing fc-23
    Re: Patience!
    Nothing like starting your morning by sticking your hand down in the green water in your skimmer basket and finding 5 dead frogs I'm awake now! lol
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Patience!
    5 dead frogs = better than a cup of coffee! Keep after it.
    Isolated Spa - 345 Gallons
  20. Back To Top    #20
    Re: Patience!
    Day 5 45 gallons of bleach used.
