Results 1 to 11 of 11
Thread: CYA Help
    CYA Help
    Hi TFP people...
    Don't post much but read, research and listen to all advice.
    I couldn't find much on what I need to know so......
    I need to raise my CYA from 20 to 80. As per calculator, I have to add 10lbs. I was going to take a trip to Lowe's but realized I have trichlor pucks someone gave me. Can I use them instead?
    Thanks
    Kelley
    PS Chem geek, I have a small crush on you.....I am the wife this is my hubby's acct.
    Thanks a bunch....!!
    Mark
    18x38 25K gallon vinyl, Hayward DE filter, Intelliflo VS pump, Intellichlor SWG, Pentair EZ Touch control system
    Re: CYA Help
    Trichlor adds CYA very slowly. It would take 23 lbs of trichlor to raise the CYA by 60. The whole process would take roughly three weeks if you used the trichlor primarily for chlorine during that period. If you have that kind of time and remember to constantly raise the PH while using trichlor doing so is possible, but I don't recommend it.
    Re: CYA Help
    Quote Originally Posted by JasonLion View Post
    Thanks, Jason.
    I guess I will turn on my deck jets and the kids waterfall to raise pH...??
    PS I have a crush on your and Birdman too......
    Mark
    Re: CYA Help
    If you are OK with taking notes and playing with Pool Math, you could add powdered stabilizer to one point then switch to tabs to get to the final destination. Kinda tricky, takes awhile. So much better to just add exactly what you need and be done with it.
    Re: CYA Help
    It is going to take more than aeration to keep up with the rate at which trichlor lowers PH. The best thing to use is soda ash/washing soda. That balances the PH and TA increases required fairly well.
    Re: CYA Help
    I went out and the CYA at my pool store. Surprisingly, it costs less than my Lowe's and Home Depot.
    Using straight CYA, do I still need to use soda ash for lowering the pH or can I just use the jets and waterfall??
    Thanks a bunch!!!
    Kelley
    Mark
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: CYA Help
    Quote Originally Posted by mrwerk View Post
    Thanks a bunch!!!
    Kelley
    No. CYA will have only a tiny affect on pH. In your reading, you have heard of the sock method, correct?
    Re: CYA Help
    Yes. Put it in a sock and let it hang in the skimmer...... right???
    How many days of doing the sock method can I expect it to dissolve?
    Kelley
    Mark
    Richard320's Avatar
    Jan 2010
    18,984
    Re: CYA Help
    It seems to depend on brand. I've seen reports from five hours to five days.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: CYA Help
    You need to knead it. If you just let it hang it takes days for it to dissolve. If you go in there and squeeze the bag for a while a couple times a day it came be all in the pool that day or next depending on how long you play with it.
    Solar Blanket, Well Water, Borax Added. 68
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: CYA Help
    Thanks, Jason.
    Intelligence is sexy, or at least that's what my wife tells me. Personally, I think it's being smart enough to know that doing what she tells me to do because she loves me helps her life be easier, and appreciating what she does for me is pretty smart as well.
