Thread: Replacement Weir door
    May 2014
    Vienna, VA
    37
    So now that I've got my pool opened for the 1st time, got all chems are dialed in and replaced the pump, I'm now trying to chip away at some of the less critical maintenance items. The next thing on my list is to replace the missing weir doors for my two skimmers (both are missing). It looks like the original skimmer design had two plastic "male" nub's sticking out from the housing to hold the weir, but on both of my skimmers at least one of the nubs are broken off. Since an original replacement door won't work, I started to look into a universal Weir.
    Does anyone have any experience with using replacement "universal weir doors"?
    The following looks most cost effective:
    http://www.poolcenter.com/p/pentair-...r-weir-r240008
    I also found the "Aqua-power" replacement weir. I have a hard time eating $60 per door but was curious if anyone on here has seen this. Is it snake oil or is it effective?
    http://www.aquapowerpool.com/#benefits
    Thanks
    -Mike
    40K gallons, IG, plaster coated with AquaBRite, circa 1987, 60sqft Crystal Water DE filter, Hayward Ecostar VS pump, SWG, attached spa w/spillway, 2 skimmers.
    May 2014
    Providence, Rhode Island
    30
    Re: Replacement Weir door
    I just went to local mom and pop pool store and told them I had no doors and what size the skimmer hole opening was and they gave me one. Works great. I think it was 9.99
    16000 oval AG vinyl (half buried-in ground)
    Hayward EC30 Perflex DE
    Hayward Power-flo Pump 1hp
    SWG Non-inline
    TF-100!!!
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    Mrd5, I am curious what did you end purchasing? I have to replace my weir door as well as the nubs broke off.
    19k gal IG plaster, built '70s, probably resurfaced in '80s-'90s; Blue Haven Hayward filter C4520BHMB (Filbur FC-1275 cartridges); Hayward MaxFlo sp2302 VSP 1.5hp; 6 solar panels 288. sq. ft. total (142"x47.5" ea.) on 1 story hm; Pentair Compool LX220 Solar Controller; FlowVis flow meter; Maytronics Dolphin S200; AG 300 gal AquaTerra spa; TF-100 & Speedstir; gone: Pentair Challenger 3/4 HP 1 speed; Polaris 280
    bbrock's Avatar
    Apr 2014
    Livermore, CA
    574
    I ended up buying the OEM weir door and works like a charm. Super shocked took about an hr to install b/c it was getting dark, was going by feel, and I couldn't tell until finally right before I finally placed it that there were slots on the left and right of the bracket that it is supposed to slide into. Now will know for next time.
    I have a busted weir (and frankly, a busted skimmer but I am getting as many years out of this thing as I can before replacing it.) I bought a skim doctor to increase the velocity of flow into the skimmer and have been really, really happy with it. Vs. last year I am doing almost no manual skimming. Cleaning it is harder than cleaning a skimmer basket, but not by much.
