Thread: How much bleach would you add here???
    Fayetteville, Arkansas
    Sure glad I don't have to use this pool. I don't think there's a chart/calculator on the planet to calculate the amount of bleach this would require!
    20x40 30,000 gal IG Liner, Pentair II Sand
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    Re: How much bleach would you add here???
    Imagine all the P in that pool
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    A zillion gallons on tanker trucks plumbed straight into the returns at full flow
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
