Thread: Help with chlorine types
    Split by moderator from HERE. jblizzle
    can "granular chlorine" (sodium dichloro-s-triazinetrione) be used in the system either as a substitute for dichlor or bleach? what would be the disadvantage? I am draining my hot tub now (has been a headache for the first 6 months, found this site and am hopeful), and have granular chlorine at home (spa store sold it to me) but no dichlor. also, if I really need dichlor, is their an "everyday" store that i could get it tonight? ie walmart, lowes, etc. . .
    thanks
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: How do I use Chlorine in my Spa (or pool)?
    Quote Originally Posted by port 13
    thanks
    Good news. That's Dichlor you've got there.
    Quote Originally Posted by spishex
    will the satisfy the CYA requirement too?
    Lynn
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Yes, dichlor will add CYA to your water. The amount required to get to 20-30ppm will depend on the volume of your spa. Or you can watch your FC levels as described in this thread.
