Thread: Help with high TA in spa
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Split by moderator from HERE. jblizzle
    Is it okay if I measured the pH , CH and TA while water was cold? About 50F? Or should I heat the water to about 100F and then measure again?
    What I got now is:
    pH - 7.8
    CH - 30
    TA - 420.
    So now I just concentrate on TA. I need to lower pH to 7.0 using muriatic acid purchased from Home Depot and then aerate till it get to pH 7.8 . Check TA again and use poolcalculator to check how much muriatic acid I need to add right now.
    Do you suggest to check the pH level after 1 hour of aerating?
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: How do I use Chlorine in my Spa (or pool)?
    Cold is fine. It will take longer for aeration to raise the pH, but the procedure will still work. Yes, you should get your TA lowered at least somewhat or else you'll be fighting rising pH. 1 hour of aerating should be plenty, but you can just check after 30 minutes to see how much the pH is risen. It should rise pretty fast given your high TA. It will rise more slowly when the TA gets lower. It also rises most quickly when the pH is low (i.e. at 7.0 that you will initially lower).
    Pysiek's Avatar
    Apr 2012
    419
    Is it okay to lower pH as soon as it rises to about 7.4? Or it's better to wait til it go to about 7.8?
    Mar 2007
    San Rafael, CA USA
    12,082
    It goes faster if you keep the pH lower so as soon as you see it rise you lower it. The rate of carbon dioxide outgassing is faster at lower pH. You can see this effect by seeing how much over-carbonation there is of carbon dioxide in water vs. air at various TA and pH levels in this chart.
    Pysiek's Avatar
    Apr 2012
    419
    Okay. I will stay by the tub all afternoon to lower the TA
