Results 1 to 7 of 7
Thread: Vacuum issues
    Jun 2014
    Jarrettsville, md.
    2
    Vacuum issues
    Hi, when I vacuum the debris. Comes back into the pool from the returns. Also when I add DE in the skimmer it blows back into the pool via the returns. What am I doing wrong ? Thanks for any Help.
    38,295
    Re: Vacuum issues
    Welcome to TFP!!!
    Well assuming you do not have a multi-valve set on recirculate, sounds like you have a problem in your filter.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Jun 2014
    Jarrettsville, md.
    2
    Re: Vacuum issues
    How do I post my info ?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Vacuum issues
    Quote Originally Posted by JeffsPool1404 View Post
    Top right of the page under "Pool School", click "Settings". "Edit Signature" is one of the options on the "Settings" page in the lower left.
    38,295
    Re: Vacuum issues
    Click the link I provided and it explains how to do it.
    30,421
    Re: Vacuum issues
    Welcome to the forum.
    Are you backwashing? How often?
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Vacuum issues
    Have you taken the filter apart to check the grids for rips? Most common issue when DE flows back into the pool and you have the valve set correctly.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
