Thread: Sequestrants
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Sequestrants
    Pool is looking fantastic but my girlfriend noticed her hair is getting a little green (not super obvious). I'm guessing it's from the pool heater that feeds the spa primarily. I only use bleach and muriatic acid in the pool with an occasional puck or two to keep the CYA where it needs to be. Recomendations on what to do? Thanks in advance.
    ~Carl
    IG Plaster with raised spill-over Spa, ~26,000 gallons, Built 2001
    Cartridge filter
    Solar heated
    38,251
    Re: Sequestrants
    Check out Pool School
    This lists the recommended sequestrants: http://www.troublefreepool.com/conte...d-metal-stains
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Re: Sequestrants
    I guess my question should have been "do I need to do anything at all?" The GF doesn't seem to mind it very much and has had it taken care of. Will I have to continually dose the pool from here on out? Just curious. Thanks!
    Cartridge filter
    Solar heated
    38,251
    Re: Sequestrants
    IF you want to prevent the hair from getting greener and/or stains developing in the pool, then you will need to constantly dose with sequestrant.
    BTW, if your pH never got VERY low, the copper did not likely come from the heater.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Sequestrants
    Check your pucks. Some of them contain copper.
    soupy8728's Avatar
    Sep 2012
    Temecula, CA
    66
    Re: Sequestrants
    My PH stays kinda high actually (7.8) or even a little more. I add muriatic acid to keep it in check. I've only put pucks in on a few occasions, probably only used 5 total so I'll double check to see if they contain copper. Could it be from the copper piping that my fill line is fed from? We have city water, not well water so I guess I'm not sure what the source is. We spend HOURS in that pool and spa so maybe it's just overexposure?
    Cartridge filter
    Solar heated
