Thread: Heater problem (will not ignite)
    Jun 2014
    Pittsburgh/PA
    3
    Sorry I realized I posted this in the wrong section so I moved it here
    Hello All
    I hope someone can help me with this or offer some suggestions
    I have a Minimax plus 200m pool heater with a VS820C gas valve
    The pilot will light and stay lite but the burner will not fire
    I jumped the TH/PP to the TH and the burner lights
    as soon as I remove the jumper it goes back out.
    So I am assuming the gas valve is still good? Any ideas as to what I should check next?
    I have access to a multi meter if needed
    Thanks
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Re: Heater problem (will not ignite)
    You could check the pressure switch and see if that's it. How clean is the filter?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2014
    Pittsburgh/PA
    3
    I have a DE filter that was just back washed with new earth added
    the pressure gauge is reading around 10
    My big problem is I have no manual or anything (came with the house) for the heater so its all a guess
    I cant seem to find anything online for my exact heater either
    It says Hercules Products millivolt heater on the outside
    inside says minimax plus millivolt purex pool systems
    model 200 M
    ps0303's Avatar
    Jul 2011
    FL
    3,684
    Paul
    Jun 2014
    Pittsburgh/PA
    3
    Thanks
    Mine is similar to that except I have no indicator lights or fans
    but I am sure some of the parts are very similar
