Thread: New Gunite Pool, New T-100 results?!?
    Jul 2012
    Oklahoma City
    72
    We plastered with acid wash 2 weeks and 5 days ago.
    PB added 3 or 4 gallons acid 1 week and 5 days ago.
    PB added 13 bags (520lbs.) salt 5 days ago.
    I added 1/2gal acid yesterday morning.
    I have been water testing daily for the last week Chlor and PH.
    This morning's first full T-100 test as follows:
    FC 2
    CC .5
    TC 2.5
    pH 8.2
    CH 250
    TA 60
    CYA <20
    Salt 4000 (SWG set on 60%, pump running 24/7)
    Any thoughts or suggestions??? PB says pH is good! Obviously he is not on board with TFP!! I was thinking about adding more MA??
    Thanks
    IG gunite Edmond, OK(OKC), 18x36 freeform ~20K, 4-8' deep, Pentair equip, (2) 3hp VS+ pump, 520 cart filter, 3 LED, Easytouch8, ItellichlorIC40 SWG, Polaris 3900 cleaner, Spa 8'x18"raised, 20' raised bond beam 2 sheers, Stonescape Tahoe Blue quartz plaster, TF-100 kit.
    Feb. 25, 2014 dig started, May 24, 2014 filled.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New Gunite Pool, New T-100 results?!?
    Is PB done?
    If so, then, yes, lower pH a bit. And raise CYA. Running 24/7 with SWG at 60%, your FC should be off the scale. The sun is destroying it almost as fast as it can be generated.
    When the plaster stops shedding dust, you can start turning down the pump run time and save some cash. And when that happens, the SWG won't be able to keep up with the solar load, so get some stabilizer (CYA) in there first.
    Jul 2012
    Oklahoma City
    72
    PB has to hookup gas line and replace remote but he is done as far as adding chemicals. He said he would be back in a couple of weeks!! PB said acid wash after plaster removed most of the dust and I have not seen much while brushing?! Filter pressure has gone up less than 3% too.
    Is there a stabilizer (what and where to get) everyone uses? And how soon should I keep adding MA? With pump running, I'm turning over 3-4 times a day. I am ready to turn that pump down to 8-10 hrs/day.$$$$ PB had it at 3500rpm and I turned it down to 2500 because it is overkill for the size.
    Thanks for the advice!!
    May 2013
    Fort Lauderdale, FL
    423
    Any CYA with no additional stuff in it will work. I get mine at Wal-mart- called "stabalizer", or the pool store will have it. Use the pool math to see how much you need. Fill up an old sock with it and hang or place in your skimmer (don't block the whole basket). It takes at least a day to soften up, then mush the sock with your hands until the CYA comes out. You need lots of CYA with a salt pool (at least 60). Also knock down that Ph to around a 7.5.....
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Richard320's Avatar
    Jan 2010
    18,967
    Back to Pool School with you!
    http://www.troublefreepool.com/conte...pool-chemicals tells you what to add and how.
    http://www.troublefreepool.com/conte...rine-generator gives you some targets. Don't obsess on TA and CH. You're okay for the moment on those.
    http://www.troublefreepool.com/conte...-pump-run-time will help you settle on a reasonable pump time.
    Now that you're doing it, a lot of the stuff in Pool School will make more sense than it did the first time you read it.
    Jul 2012
    Oklahoma City
    72
    Lol….
    Thanks again, your "pool is like a pet"….. is perfect!! Take care.
