Results 1 to 11 of 11
Thread: Advice on replacement pump?
    Apr 2014
    Oklahoma
    66
    Hello all,
    My pump has been leaking like crazy and the motor began smoking last night so I think its time for a replacement. Changed gaskets and seals, I think I have a cracked housing.
    Current pump = Hayward Super Pump II 1.5 HP (I believe it has 1.5" piping, but the specs on this motor say 2", I'll have to check when I get home)
    Current filter = Hayward S244T Sand Filter
    Number of Skimmers = 1
    Number of returns = 5
    The equipment pad sits about 1-2 feet above water level and is about 50 feet away from the skimmer.
    Is my current setup too much or would I be able to go for a regular Super Pump with less HP? Please take into account I'm quite the newbie with pools, first year owning one.
    Any input is appreciated!
    11k IG Gunite, Hayward S244-T Sand Filter, Pentair SuperFlo 1HP Pump, TF-100 Test Kit
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Advice on replacement pump?
    You don't mention any water features that require high flow, so you do not need a pump that big. Being in Oklahoma, you don't have high electricity prices, so a variable speed pump would not be worth it. However, a two speed pump normally run on low, except for vacuuming and back-washing, would save you money in the long run. Assuming your existing pump is 230V, I would get a 1hp two speed regular Super Pump or equivalent. If you get a two speed pump, you will also need a switch to change from high to low. Some pumps come with the switch.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    38,528
    That is a big pump and it does not appear that you have anything that would warrant such a large pump (spa / water features / etc) plus the smaller pipes are not really helpful for the big pump.
    I would recommend a 1HP 2-speed pump ... like the Pentair Superflo that I have or a Hayward Super Pump. As sargent pointed out most of these 2-speed pumps are 230V, so check what you currently have. Also the Superflo comes with a switch, I am not sure about other pumps.
    Apr 2014
    Oklahoma
    66
    I'm pretty sure I'm running 230V due to the breaker having dual posts. Any specific reason to pick Pentair over Hayward? I think I'm going to stick with a single-speed but am considering changing brands.
    38,528
    All the major brands are similar. I guess if you do not feel like saving yourself 50%+ off the power costs to run your pool, then stick with a single speed.
    Apr 2014
    Oklahoma
    66
    My electric bill is the same each month, despite what type of pump I ran. Plus I've put too much money into trying to save my current pump so I'm really thinking immediate cost savings.
    After looking at the specs between the Pentair SuperFlo & the Hayward Super Pump II, I'll have to resize my pipe fittings. So my question is:
    Is it bad to have 2" pipe going into 1.5" directly into/out of the pump? I know it'll restrict flow a bit but anything other than that?
    38,528
    It is good to have 2" pipe. Does not matter what the pumps require, just use adapters. The Superflo comes with unions for either size pipe.
    Um, you have not used a low RPM pump, so of course your electrical bill is always the same.
    Apr 2014
    Oklahoma
    66
    Thanks for the input. And when I said my bill is the same, I mean I'm on an static plan. I pay the exact same amount year round, so even if my usage went up, I would still be paying the same that I am now.
    38,528
    I have that power plan as an option too, but they will adjust what you have to pay next year based on actual usage. You do not have unlimited power and will pay eventually.
    Apr 2014
    Oklahoma
    66
    New pump ordered! I appreciate the input everybody.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    If you are getting a one speed pump, you probably should get a 3/4 hp or perhaps even a 1/2 hp if you want to save a little money on electricity. Here is a good buy on an uprated 3/4hp Superflo pump.
