Thread: Oval Pool Wall Not Straight
    May 2014
    Columbus, ohio
    17
    Please start your own thread by selecting New Thread at the top of every forum you wish to use. Casey~ Split from Is-this-normal-(walls-of-oval-pool-not-straight)
    Can I found out to. I am new to this still trying to figure how to post. I have a used 15x30 and got it almost the way filled and noticed that walls look like they are bulging. Some of the buttress are not straight any more. Help please!
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Oval Pool Wall Not Straight
    Hi there Wolfe, did you install this pool yourself, or was it professionally installed....?
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    May 2014
    Columbus, ohio
    17
    I installed it my self
    15x30 52" 92030 gallons above ground cartridge pool 10 years old bought 1 month ago installed last weekend
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Do you have any pictures?
