Results 1 to 11 of 11
Thread: becky5687 says Hello from Michigan!
    becky5687's Avatar
    Jul 2008
    SW Michigan
    26
    Well, we finally did it! We have a pool! Just a started Intex pool, we will probaly upgrade in the next year or two. I am so glad I found this site! We just finished filling our pool this afternoon and plan on attempting the BBB method starting tonight.
    Woo Hooo!
    15 X 30 oval AG ~ 12,000 gallons. (completed June 23, 2012)
    1 HP Cooper Ranger Sand Filter
    BBB Method / TF100 Test Kit
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Re: becky5687 says Hello from Michigan!
    That's terrific. It's great that you are starting now. With just a little effort on the front end, you'll be able to avoid all the green pool headaches.
    Welcome to TFP!
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    krcossin's Avatar
    Detroit Burbs
    113
    Welcome my neighbor Becky5687.
    What part of the mit are you from? I'm a Livonia/Westland guy.
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Welcome!
    becky5687's Avatar
    Jul 2008
    SW Michigan
    26
    I am from Southwest Michigan, South Haven to be exact. I grew up in Redford Twp so I am very familiar with your neck of the woods! Can't wait to get this pool ready and take a dip, it has been way to hot lately!
    krcossin's Avatar
    Detroit Burbs
    113
    Funny, I am at work which is located in Redford Twp. small world huh?
    Behind the Oil refinery, across the railroad tracks from the ice arena - Connelly Crane.
    I suggest you take some time reading the pool school info and get a good test kit. Once you are able to get everything in balance, your maintenance work is simple. Next year is when you will find owning a pool simple and more enjoyable. This year you have a lot to understand, be patient.
    May 2008
    SE Michigan
    38
    Welcome becky5687,
    I grew up on Seminole north of Schoolcraft (Inkster and I-96). If you know Schoolcraft, you were around before the freeway (I'm old). I live in
    Salem Township now, most people have to Google it. Welcome to the forum. Ask for advice and the fine people here will help. Follow it and
    you'll have a beautiful pool. If you don't already have a GOOD test kit, the TF-100 through this site is a great kit. Good luck and happy swimming.
    Skinman
    16 x 32 Doughboy AGP
    Doughboy 17" AquaView sand filter
    1 HP, 2 Spd. pump
    (4) 2 x 20 Sunheater Solar Heat
    Solar cover w/reel
    TF 100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    becky5687's Avatar
    Jul 2008
    SW Michigan
    26
    What a small world, two people who are near the area I grew up!
    skinman - I am not old enough to remember when I-96 went through, but my mom is. SHe was one of the first classes to graduate from Thurston High (1963).
    Thanks everyone for the warm welcome. So far so good, put the Bleach and CYA in last night to get started. I have already received a ton of help from all of you!
    Thanks!
    Becky
    krcossin's Avatar
    Detroit Burbs
    113
    I was in elementary school when they built 96, my grandfather did some of the cement for it. I remember watching the parade.
    Hi!
    26,000 gal liner IG pool
    Doughboy with concrete construction
    Full sun most of the day
    1.5 hp pump system
    200lb sand filter
