Results 1 to 8 of 8
Thread: FAS-DPD Test
    Jun 2014
    Northern CA
    10
    FAS-DPD Test
    I purchased a K2006 kit this season to do my own testing. Ive been using it and it is great, way better than going to the pool store!
    I have one question regarding the chlorine testing. I was having trouble getting chlorine to even register with the test no matter how much bleach I dump in, so I was concerned perhaps I was testing wrong (slight algae/ammonia problem, better now...still SLAMing!) Anyhow, I watched the how to video by taylor showing their test and have also watched the video for the TFtestkits version. Same powder and same scooper in both kits correct? why does taylor instructions say 2 scoops and TFtestkits says to use one?
    Can someone clarify for me? my thought is why use 2 scoops if I only need 1... powder will last twice as long right?!!
    Thanks!
    38,279
    Re: FAS-DPD Test
    Depends on how much you define a scoop to be. You can not use too much powder, but too little can be a problem. One scoop should be plenty are normal levels, you might need two while SLAMing.
    Have you also been testing the CC?
    This is a time when the OTO chlorine test that comes with the TF-100 is useful ... to be sure whether there is really no chlorine or not.
    May 2014
    Clinton, Mississippi
    24
    Re: FAS-DPD Test
    Quote Originally Posted by nopoolstore View Post
    Thanks!
    I was wondering the same thing... the Taylor video shows someone using such heaping scoops that it may as well be 5 scoops instead of 2...!
    ____________________________________________________________ ___________
    15,000 gallon in ground pool with liner, Purex Triton Tagelus sand filter, Pentair Superflo 1HP.... Clinton, MS.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: FAS-DPD Test
    One heaping scoop is the perfect amount. Period.
    Essential Links:
    Re: FAS-DPD Test
    Taylor assumes two level scoops, TFTestKits specifies one heaping scoop. They are both the same amount of powder, just two different ways to get there.
    Mar 2014
    Northern CA
    18
    Re: FAS-DPD Test
    Would the same amount of powder be used for both the .5 and .2 resolution tests? It would seem that if you're using a 10ml water sample vs. a 25ml water sample that less powder would be required, though there may not be a proportional relationship there.
    Re: FAS-DPD Test
    The Taylor directions say to use the same amount of powder, though logically you should need more powder when you have a larger sample. Actually, the larger sample can't measure FC levels nearly as high as the small sample, and you need enough powder for the total amount of chlorine in the vial, so using the same amount of powder actually makes sense.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: FAS-DPD Test
    Thank you Jason.
    Essential Links:
