Results 1 to 17 of 17
Thread: The world's most crowded swimming pool
    Dec 2007
    Central New York
    504
    What's the chlorine reading in that pool?
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Staten Island NY
    116
    Re: The world's most crowded swimming pool
    0. Its green and I can't see the bottom!
    -400 sq ft ingroung Fiji (straight back kidney) ~ 13,500 gallons - Vinyl Liner - 3 to 6 Feet
    -Hayward 1.5 HP Super Pump
    -Hayward Perflex DE Filter EC65A
    -Hayward H 250 Heater
    I'm sure there's a long line at the bathroom... or not
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    ewwwwwww
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Mar 2007
    San Rafael, CA USA
    12,082
    That looks a little more than the 1000 gallons/bather/day that designates "high" bather load. Maximum bather load standards vary, but are on the order of 30 square feet of surface area (3 foot radius circle) in the deep end and 15 square feet of surface area (2.2 foot radius circle) in the shallow end per bather. Certainly looks like a code violation to me!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Could you imagine the mass hysteria should a Baby Ruth Incident take place
    May 2008
    Austin, TX
    27
    Where is this?
    It looks like China or maybe Japan. I don't see any tattoos (they don't let people with tattoos in public pools in Japan).
    I can't imagine that would be any fun.........standing in water with a couple thousand of your closest friends.
    12' x 28' Doughboy, partially underground, 9100 gal. Hayward pump and sand filter, Barracuda Zippy pressure side cleaner.
    Mar 2007
    San Rafael, CA USA
    12,082
    The link to the article is here. The location is in Penglai in Sichuan, western China.
    Cassiopeia's Avatar
    Jun 2008
    Tampa Bay FL
    46
    Quote Originally Posted by Molson
    ewwwwwww
    BIG DITTO FROM ME!!!!!!!!!!
    15' ROUND, 52" AG
    Newbie at pool ownership!
    Jul 2007
    Brisbane, Australia
    874
    Quote Originally Posted by chem geek
    Codes are different in different countries
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Is this the same pool?
    [youtube:3j5dbut3]inA-36YRV0Y[/youtube:3j5dbut3]
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Regardless of the water....which just grosses me out to think about...as a former life guard I'm really surprised that would let that many people into the water. Some one could so easily get run over by a float and then be "trapped" under the water and no one would know there was a problem until it was too late.
    26,000 gal liner IG pool
    Doughboy with concrete construction
    Full sun most of the day
    1.5 hp pump system
    200lb sand filter
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    That looks really nasty. You could probably pick up something in there that soap and water won't wash off. Yuck.
    17,000 gallon roman shaped gunite pool-AquaRite goldline SWG
    Dec 2007
    Central New York
    504
    Another picture of the pool.
    Hotrod30
    Pentair VF3050 pump
    West Michigan
    108
    Unless you were going for a new worlds record why would so many people want to get in at one time? Looks pretty gross and dangerous to me. Give me my little frame pool for the few warm months we have. I pass on the comunity petrie pot! Kimrst
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    Jul 2007
    Brisbane, Australia
    874
    They have a lot of people in Japan, and not enough space to build swimming pools.
    searayboater's Avatar
    Jul 2008
    The Great State of Texas
    65
    I wonder how much the temp went up in the pool with all those people?
    18' AG Pool, 6900 gallons, 55 sq. ft. Hayward Easy Clear Cartridge Filter, 1hp Power Flow LX Pump, North Texas
