Thread: Replacing one third of pool water to reduce CYA
    Baton Rouge, La.
    75
    Tomorrow I am replacing a third of the water in my fiberglass pool. A while back someone posted a technique for removing water and filling at the same time. I'll use a sump pump to pump water out and a garden hose to put water back in. I can't remember if they said to put the pump deep and hose at other end of pool at top or vice versa. Anyone remember..
    Trilogy "Fiberglass" Pool,
    15x34 8900 gal.
    Pentair 1hp Super-Flo Pump
    Pentair CC100 Cartridge Filter, Pentair "Legend" Cleaner
    Re: Replacing one third of pool water to reduce CYA
    If your fill water is colder than the pool water (common), fill deep and drain high. If your fill water is warmer it is the other way around fill high and drain deep.
    Baton Rouge, La.
    75
    Thanks...That is what I was looking for!
    15x34 8900 gal.
