Results 1 to 7 of 7
Thread: Need to SLAM, PH is 7.8
    May 2013
    Norman, Ok
    35
    Need to start SLAM process, but PH is 7.8. So should I lower it first or just start dumping in bleach (recommended amounts of course) and get dead armed from brushing?
    18 x 30 IG vinyl "sports pool" 16k
    Hayward pump & sand filter. Polaris cleaner (older model) & booster pump.
    K-2006 test kit
    30,432
    Re: Need to SLAM, PH is 7.8
    Pool School will tell you that 7.8 is on the high side but still within an acceptable range of 7.2 - 7.8.
    SLAM away!
    May 2013
    Norman, Ok
    35
    SLAM away!
    Thank you Sir Dave!
    Started and brushed for 45 minutes...checking FC one more time, then heading to bed with my arms feeling 2 inches longer.
    K-2006 test kit
    May 2013
    Norman, Ok
    35
    So...8:30 last night- my CYA is about a 35, so I added the appropriate amount of bleach and brushed twice before midnight. 12 hours later the over night test showed no loss of FC less than .5 of CC yet I've still got brown dirt/residue on the bottom of the pool. I honestly thought it was algae, but now have my doubts. I just read about others having similar problems from Cottonwood trees, and boy are they in full bloom right now...could this be the reason I continue to have dirt/residue on the bottom of the pool, especially at the corners and creases?
    Pool is clear, except for the residue, wife says its very gritty, not slimy.
    Thoughts?
    K-2006 test kit
    38,520
    Get out the vacuum and clean it up.
    May 2013
    Norman, Ok
    35
    I can do that! And just to make sure I'm on the same page, FC is staying the same over night meaning that its not an algae problem, correct?
    K-2006 test kit
    Jun 2011
    Long Beach, CA
    2,790
    Correct, just needs to be vacuumed.
