Thread: In-law's pool green. Need advice.
    Jun 2014
    Tucson
    3
    Hi all,
    I'm new to the forum and looking for some help. My in-law's pool has turned green and they're having trouble getting it to clear. Please help or my kids' summer is in trouble. Thanks in advance.
    17,000 gal plaster pool - sand filter
    Hardness 1000
    Total Chlorine 3
    Free Chlorine 20
    pH 8
    Alkalinity 120
    Stabilizer 100
    Photo attached.
    38,267
    Re: In-law's pool green. Need advice.
    Welcome to TFP!
    Short answer is:
    Order a recommended test kit.
    Read Pool School while waiting for it.
    Replace water to get the CYA to a reasonable level.
    Follow the SLAM process to clear it up.
    Jun 2014
    Tucson
    3
    Thank you Jason.
    I will give it a try.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,982
    Welcome!
    That's a pretty shade of green
    As long as there aren't a bunch of leaves and branches and dead animals hidden beneath the surface, you can clear that mess in a few days. The problem is the test kit. It's difficult to find a FAS-DPD tester in stock at a store; maybe not where you live though, since it's pool-land. You can make a few calls and see if anyone has a K-2006 in stock; most pool stores will try to sell you a K-2005 DPD tester and tell you it's the same, but it isn't. The Leslie's part number is 81329. If you have to order it and wait anyway, don't bother; the TF100 is a better value. Get the XL option since you're clearing a swamp.
    Here's some folks who have done it recently:
    http://www.troublefreepool.com/threa...gross-numbers)
    http://www.troublefreepool.com/threa...ool-is-winning
    http://www.troublefreepool.com/threa...-to-Clean-tale
    http://www.troublefreepool.com/threa...glorious-swamp!
    Just do what they did.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Welcome!
    Total chlorine = free chlorine + combined chlorine
    There is no way your free chlorine can be more than total chlorine. While you are reading through pool school check out the "ABC's" article. Part of the TFP way is understanding what all these parameters really mean and how they affect your pool.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
