Results 1 to 8 of 8
Thread: Clorox vs store brand bleach
    Today I went to Target to stock up on bleach and their $2.99 store brand was cleared out. I went for the $3.49 Clorox and I love it. Their bottles are more ergonomic and they have an air flow hold built into the handle. As I slowly dispersed the Clorox and walked around the pool, no bleach splashed back up at me. I've already ruined two pairs if workout pants and a cute top from bleach stains from the liquid splashing. I think the Clorox containers are much more user friendly! Sure it's more expensive but it's worth it if it saves my nike running pants!
    17,000 inground gunite pool finished June 2013. Pentair variable speed something or another. Polaris cleaner, inline rainbow chlorinator. Using trichlor until CYA reaches 50-60.
    38,547
    Re: Clorox vs store brand bleach
    Sounds like you are not adding the bleach in the manner we recommend and thus splashing your clothes.
    Why not pour it slowly in front of the return jet?
    Jul 2009
    Gonzales, La
    220
    Why not pour it directly into the skimmer? That way it's distributed to the whole pool when returned.
    15x36 Gunite w/Diamond Brite(Bahama Breeze plaster), 3.5-6', Pentair Easytouch Automation panel, Pentair 3HP VS pump, Pentair CNC 420 filter, Pentair 5G color changing light, Polaris 360 cleaner w/booster, Pentair IC-20 SWG
    My pool build
    http://www.troublefreepool.com/threa...ales-Louisiana
    30,432
    Not as good as pouring it gently in front of a return.
    A high concentration of chlorine going directly into the pump and other equipment can be harsh. Once or twice is surely no harm but done over a long period of time can be really tough on seals, gaskets, etc.
    Gently in front of a return is the best method of introducing most chemistry (but not all) in any pool.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    X2
    Highly concentrated streams of Chlorine, as would be if you poured it into the skimmer is also very hard on Copper heat exchangers in pool heaters.
    Most of us have Copper HX, so it's best not to do this. Just pour it slowly in front of a return. It's so easy.
    Essential Links:
    I found the Clorox bottle harder to pour than the generic bottles. I'm pouring slowly, so I don't need a breather hole and the opening is smaller because of it. The only time I've had bleach stains was when a bottle fell out from under the cart at Walmart. I'm still hearing about that one.
    20,000 gal in-ground plaster pool with sand filter. Replastered recently. Mostly adding bleach and acid. CYA was high when I took over.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I like the Clorox bottle as well. I tried generic (6%) and got tired of having to pour so much more than I was with the 8.25%. Now I've got to get time to call the bulk distributor so I can get some 12.5%
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    The only bottles I've had a problem with are the actual gallon bottles of austins brand liquid chlorine. They are taller and skinnier than the walmart/target/grocery store brands I usually use. It always drips down the side when I pour.
    Mine goes into a measuring cup because I only use about 20 oz a day.
    The dripping down the side is a pain. I might just stick with the store brands! Wouldn't spend extra for the clorox though!
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
