Thread: One of three jets not flowing
    Jun 2014
    Rush, NY
    2
    I have a 24,000 gallon in ground pool. This spring, I have had some problems getting it started. First, the pump failed to move any water, so I replaced the gasket, added some more lube to the O rings, and tightened a few things. Now the water is flowing and doing so without air. However, one of the returns is producing no water flow. Both skimmers and the drain are providing water, so the problem seems to be on the pressure side of the pump.
    Any ideas?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: One of three jets not flowing
    Have somebody hold their hand over one of the working returns and see if the other starts flowing. You can also turn one or both eyeballs on the working returns 90 degrees and see what happens.
