Thread: Pentair WisperFlo 1.5 HP Pump & Motor
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I just noticed that when my pump starts it squirts a shot of water out, now this only happens on starting, then runs with out leaking...It doesn't leak when off..
    You think the shaft seal is going?
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pentair WisperFlo 1.5 HP Pump & Motor
    Where is the squirt coming from? Sometimes pumps will leak out of the pump lid on start up or shut down.
    Mark
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Quote Originally Posted by mas985 View Post
    It shoots out so fast I can't see it, I think from one of the motor vents slots....
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    I did fixed this, the motor bolts were loose.
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
