Results 1 to 9 of 9
Thread: Hayward CL100 Automatic Chlorinator
    Mar 2012
    Maryland
    87
    I'm looking at this for the first time. It holds 9 lbs of Trichlor tabs!!! I'm used to adding the tabs to my skimmer basket. What's the difference??? Can I save on tablets by using this device? Is it just a convenience device.
    13,500 gallon above ground round pool. Vinyl Liner. Hayward S244T 3.1 cu ft sand filter. Hayward Powerflo 1HP pump (single speed induction). HTH 6-way test kit.
    38,508
    Re: Hayward CL100 Automatic Chlorinator
    Putting tablets in the skimmer is not recommended unless you run the pump 24/7. They are very acidic and could damage the skimmer and equipment. The chlorinators allow you to dial in the output, you would not use any more/less to maintain the same FC level.
    Of course you realize that we RARELY recommend the use of trichlor tablets due to the side-effects of rising stabilizer levels and lowering of pH and TA. See: How to Chlorinate Your Pool
    Mar 2012
    Maryland
    87
    Thanks, yes I started here and know about the BBB method. It's just easier to use the tabs. I used them one year and it was easier and more convenient. I usually use liquid bleach and the pool calculator.
    38,508
    We see so often that people use the pucks for a year and 2 and suddenly start to have problems ... because they do not realize that the CYA is climbing. If they work for you and you are testing your chemistry, that it great.
    Mar 2012
    Maryland
    87
    My CYA levels reset each year!!! I don't know why, but one year I overdid the CYA. Instead of changing out the water I let it go for the entire year, adding more chlorine!!! By next year my cya level was almost 0. I have a 24' x 4' deep above ground pool.
    38,508
    We saw a LOT of that this year, where the CYA was converted to ammonia and requiring a long initial SLAM to eliminate it.
    Mar 2012
    Maryland
    87
    Yeah, I learned this from a article....
    http://www.troublefreepool.com/threa...ric-Acid-(CYA)
    What is SLAM? You mean lot so CL?
    38,508
    Azmp1's Avatar
    Jul 2012
    Maryland
    284
    if you gonna use Hayword cl100 chlorinator I can attest that it does work great being able to set the desired chlorination level is great, my pool uses much less chlorine because I keep it covered unless we're swimming, so for me being able to set it to a minimal level and maintain it at that level is pretty important.
    32000gl freeform gunite/diamondbrite perl pool || Jandy Sheer Descents || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS6 w/Aqualink touch || Jandy iAqualink2.0 || Pentair Intellibright LEDs || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 140k BTU heat pump
