Thread: Natural Gas question
    I want to istall a Raypak 336 natural gas heater. I checked the sizing and it exactly what I need for my inground pool. My problem if I do have one is that I currently have natural gas running into my garage that I use to heat it in the winter. My pump room is a room just off the garage. The line is a 63 foot underground line that is 1 inch. it then goes to a 50 foot section in the garage itself that is also 1 inch. Do I have a large enough line to handle the 336? if not what options do I have, dig it up to a larger line or can I do a two stage? Any help would be appreciated.
    Randy
    22yr pool owner, 21 yrs Baquacil, installed SWG 2009 - (22000 gal Vinyl In-ground pool)(Pool Pilot DG-220 SWG)(Hayward S244T Sand Filter 3.1 sq ft area 20 gpm)(Hayward SP2607X10 1hp pump)
    38,272
    Re: Natural Gas question
    Where you been for 5 years?
    That does not sound big enough to me. There are calculators for pipe sizing here: http://www.engineeringtoolbox.com/na...ing-d_826.html
    I have a 3/4" pipe that feeds the house (which I think is too small, but everything seems to work) and then a 1 1/4" (or larger, not sure) pipe from the meter to just the pool heater.
    Aug 2013
    Maryland
    93
    Likely not big enough. I would ask to get a 2 psi system, then have a regulator on the end to bring it down to standard pressure.
