Thread: Stains on pool liner
    Jun 2014
    George/Iowa
    1
    Hello, I am new to this site. I have a 24' Dough Boy above ground pool. Here is my problem. This past fall (after I closed up the pool) we had a storm come through and destroy the winter cover. I never replaced that cover (my mistake) and the pool ended up with lots of leaves and debris in it. When I went to get the pool ready this spring, the water was very greenish/brown. I got the water to be clear again, and got the leaves and debris out of it but now the liner is stained. I talked to the place I purchased the pool and showed them the pics. Their suggestion was to shock, shock, shock, and scrub with a brush. I have tried this and it is not working at all. Any suggestions on how to get the stains off the liner? Is there a good chemical I could use to get rid of these stains? The pictures I attached are after shocking and scrubbing.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Stains on pool liner
    Welcome to TFP!
    Chlorine and brushing should have removed organic stains.
    Try scrubbing a stained area with a Vitamin C tablet from the drug store. If it lightens or removes the stain, it indicates the stain is a metal deposit.
