Thread: EasyTouch Pool Only to Pool and Spa mode
    Jun 2014
    Las Vegas, NV
    1
    Hi. Basically, I want the Intellichlor to work in spa mode at the spa levels set. Currently it always works at the pool levels in both pool or spa mode. I think this is because it is a single body automation system. So the question is, how can I get the EasyTouch single body automation to work like a pool and spa automation system. For the two different systems, the two circuit boards have different numbers but appear to be identical so I'm hoping it is a software, firmware or simple jumper change.
    Re: EasyTouch Pool Only to Pool and Spa mode
    Welcome to TFP!
    I know it isn't just a jumper. I'm fairly sure it is different circuit boards.
