Results 1 to 7 of 7
Thread: liner fallling apart
    May 2014
    south jersey
    21
    Moved in last September and I am waiting for a new liner that will be here next week. My first pool - inground/vinyl liner - and don't know a ton about pools yet. In the meantime - my liner is totally falling apart and ripping around half the pool. There is a lot of water behind the liner because the liner is ripped around the top and dropping into the water. Is this fine for the next week until the pool guys come and replace the liner. Is there any difference when they drain the water behind the liner and the normal water above the liner - it's all just drained from the main drain anyway right? I have a pump to pump groundwater from under the liner but there is really no point in using it because the water from the pool will just keep going behind the liner anyway and I don't want the water level getting too low. So am I okay like this until next week? I don't know what I could do anyway but just curious since the pool is not looking too good!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: liner fallling apart
    you should be fine to wait till the pool guys come.
    Divin Dave,
    DeeMac's Avatar
    May 2012
    Munster, IN
    123
    We had our liner out about a week before our new one came. I would make sure that you don't have rain in the forecast. Do you have sand bottom? You would not want that getting wet before the new liner comes.
    16 x 34 inground vinyl pool
    Hayward 1 hp super pump
    200s Hayward Sand filter
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I'd want to pump it out and inspect for any damage from the water getting behind the liner before they come out..
    It's helpful to add your pool info to your "signature". Can you post some pictures of the present liner ??
    1. The size of your pool in gallons
    2. If your pool is an AG (above ground) or IG (in ground)
    3. If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    4. The type of filter you have (sand, DE, cartridge) and, if you know, the size, model number or flow rate of the filter.
    5. If you know, please tell us the size pump in HP. Also mention if is it a two speed or variable speed pump.
    6. Date of pool build/install, particularly important if less then a year old.
    7. Other significant accessories or options, such as a spa , SWG, or cleaner
    Solar Blanket, Well Water, Borax Added. 68
    Nov 2011
    Moberly,MO
    1,010
    As a pool builder I would recommend leaving it until they come to put the liner in. You could cause more problems by pumping it ot and leaving it sit for a week or more. Just my 30 years of experience talking though.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    What Swimcmp says ... I edited my previous post ...
    Quote Originally Posted by swimcmp View Post
    Divin Dave,
    May 2014
    south jersey
    21
    thanks everyone - it is an IG vinyl liner pool, DE filter - that's about all I know at the moment it is still new to me so I have some learning to do. sounds like i will just wait for the pool guys to take care of it!
