Thread: Pressure gauge jumps when pool is in "Spa Mode"
    Oct 2013
    Santa Clarita, CA
    12
    I noticed the other day that when I set my pool to run in "Spa Mode", the pressure gauge on the filter jumps up from about 12psi (where it normally is in "Pool Mode") to about 20psi. This pressure rise only happens when the valves are set for spa operation.
    Is this normal?
    17.5K inground plaster pool/spa, Aquapure PLC 1400 SWG, Jandy stealth 1.0 hp pump, 1.5 hp booster pump, Jandy 60 sqft DE filter, 400,000 btu heater, Zodiac MX 8 cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Pressure gauge jumps when pool is in "Spa Mode"
    I'd say yes. My pool does the same. Instead of 3 good-sized pool return fittings and two partial-flow spa fittings, the pump is all the sudden only feeding two jets. Higher pressure gives more velocity and more bubbles and all that I assume. 12 and 20 psi are great numbers. I wouldn't be at all alarmed.
    Oct 2013
    Santa Clarita, CA
    12
    OK, that makes sense. Sort of like putting your thumb over a garden hose and all of a sudden it's spraying with more pressure. Thanks!
