Results 1 to 13 of 13
Thread: Yeti coolers
    Yeti coolers
    So we are still working on our pool amenities. Has been slow going recently and staying out of the pool in this heat instead of working is hard. .
    We are building a bar area under our gazebo and was going to put a small under the cabinet refrigerator out there. I then had the idea of a cooler which gave me a excuse to get a yeti cooler. My thinking is we will be replacing a refrigerator every few years at a $200-$250 cost each time being in the south it would run 24/7 and probably not keep anything really cold. I got a deal at a local yeti dealer for a 50qt. 20% off and no tax. I figure this thing will last a lifetime and should keep the beers plenty cold for the weekends.
    I am planing on building it into the bar making the top even with the countertop.
    Anyone else go this kind of route?
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Yeti coolers
    The only problem I see is draining all the water after every use. Of course you also have to haul ice unless you have a mega fast ice maker.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Re: Yeti coolers
    I plan on making it so it can be taken out so draining shouldn't be a problem. If reviews are true this thing can hold 20 pounds of ice for a week, probably shorter given people will be in and out of it a lot though. If I can go a 3 day weekend with it getting opened several times a day with 20 pounds of ice I will be happy though.
    38,305
    Re: Yeti coolers
    I was looking at buying a high end cooler like this (Pelican/Yeti/Engel/Esky/Denali), in the end could not justify the cost. They are great, very heavy duty, etc. But I never need to keep ice that long for weekend camping.
    Ended up getting a larger 6day Igloo with actual metal hardware (no plastic hinges/latches) for 1/3 the cost ... I can buy a LOT of ice for a few hundred bucks.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Yeti coolers
    I have a 65 qt Yeti. The only way the Yeti will keep 20 lbs of ice for a week is if you keep it inside before filling it and fill it with pre-cooled drinks. If you start with a hot cooler and room temperature drinks your first batch of ice won't last as long. Once you have the drinks and cooler cooled down, then yes... 20 lbs will last you closer to a week. That said, the Yeti is hands down a much better cooler than the el cheapos out there.
    Another important note... order a Coleman motion activated cooler light for it off Amazon or eBay. It sure makes it a lot easier to find your favorite drink after dark.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Yeti coolers
    Got one of these @ Sam's over the weekend: http://www.samsclub.com/sams/retro-party-cooler/prod13080120.ip?navAction= . Yes, it requires 110/120 v electrical connection, but anything I can do to lessen dependence on ice is a good thing. Plus no draining and no water-logged beer bottles and Coke cans at the end of the day. Just another alternative to think about.
    For the record, when it comes to traditional coolers, Yeti's are the Rolls Royce of coolers. Our tailgating crew has one and it has performed quite well. Just need a few lineman to lift it when it is fully laden.
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Yeti coolers
    Quote Originally Posted by BoDarville View Post
    Does that thing have a drain in the bottom? I think the combination of the two (ice and refrigeration) would be a powerful combination. You could ice the drinks and keep it from melting for days or maybe even weeks.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Yeti coolers
    The retro party cooler does not have a drain. Agree that having both refrigeration & traditional ice coolers are a good combo. The refrigerated unit is great at home since an electrical connection is conveniently available and it is one less thing for which I need ice. OTOH, the coolers are usually the only viable option where electricity is not available such as at tailgates.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Yeti coolers
    That's "cool" Bo.
    Ga mike's Avatar
    Mar 2014
    Georgia
    85
    Re: Yeti coolers
    I am on a BBQ competition team. We use the Canyon Brand of coolers. They are like the other brands but less expensive. Let me know if anyone needs any info in them.
    20x45x32x18 L Shaped vinyl Pool
    Pentair Superflo 1.5 vs pump
    Pentair t100 filter
    I 60 cell
    Madison Mike's Avatar
    Apr 2014
    Columbus, WI
    31
    Re: Yeti coolers
    I was going to pull the trigger on a yeti a few years back. I am thinking it was around $400 for a 48 quart model. Common sense kicked in and I didn't buy the over priced roto-molded piece of plastic to keep a beverage cold.
    Jacuzzi J375 Spa, 415 gallons, Bromine Sanitizer
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Yeti coolers
    I love expensive things, but I will never, ever give that kind of cash for a cooler. I think they are nuts! I'll save that cash for something much cooler than a cooler....
    Essential Links:
    Ga mike's Avatar
    Mar 2014
    Georgia
    85
    Re: Yeti coolers
    We sell canyon coolers for half that price
    Pentair t100 filter
    I 60 cell
