Results 1 to 10 of 10
Thread: Uneven AG pool
    Apr 2014
    Naperville IL
    15
    Uneven AG pool
    Hey all.. I just wanted to see if anyone has had experience with a problem we're having with our AG pool. We just bought the home in Dec. and when we opened it we noticed that the ground has raised on one side. More specifically it appears that on of the posts has raised about 2-3 inches. As a result the water level on that side is approx. 2-3 inches lower than on the opposite side. I wanted some opinions before I bring out a company to take a look. The simple idea would appear to be just digging out the high side and re-leveling the pool, but having no pool construction experience I worry I would end up just causing further damage or causing a catastrophic failure. Any thoughts or experience with this?
    Thanks in advance!
    18 ft. AG pool, 3.5 ft. deep, 6700 gallons.
    Hayward power flo LX with a Hayward star clear cartridge filter
    We inherited the pool when we bought our house. We were told the liner is a year old (it does look good!)
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Uneven AG pool
    When you get time, upload some pictures. It will help the fine folks here to diagnose your problem better.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Uneven AG pool
    Its definitely time for a re-level... Whether you chose to do it yourself or not is totally up to you... It may depend on a few factors, if you're not DIY'ers But doing yourself may take longer, but can save you substantial dollars...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Uneven AG pool
    Re-level is the answer. It can be done easily enough. (easily enough being a subjective term) Mostly its just manual labor and using a laser level or water level to get the ground even. It does require a considerable amount of digging and moving dirt by hand. If you have a tractor with a box blade or some other machinery to help, then it will be much easier.
    Divin Dave,
    Apr 2014
    Naperville IL
    15
    Re: Uneven AG pool
    I will definitely upload some pics when I get the chance. I am a DIYer for most things but like I said I hesitate with things I have no experience with. Am I complicating things or is it as easy as just digging under the high side and letting it settle to level? Do I have to be especially careful not to puncture or damage the bottom or are the bottoms able to withstand mild trauma while digging? Also, is it better to do it with the pool full or after closing when the water level is lower? Thanks again.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Uneven AG pool
    I really dont know how you can dig out the high side with the pool set up. It would be like digging under and elephants foot.
    Previous posts Im sure were assuming the pool would not still be set up.
    You might should wait and at least see what the pool guys say. Maybe they know some tricks....
    Divin Dave,
    May 2014
    SW, MO
    58
    Re: Uneven AG pool
    I've seen people relevel when the pool is full, some have been successful but most have had poor results with full collapses or/and bent legs. It's just not safe to do. You need to drain the pool, move it and relevel it properly, then set the pool back up.
    Apr 2014
    Naperville IL
    15
    Re: Uneven AG pool
    Divin Dave.. I thought there may have been a miscommunication.. I didn't think it would be as simple as just digging. I suppose it's probably better to see what a builder has to say about it. Thanks again!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Uneven AG pool
    Man, let us know what those guys say. Im interested in what they come up with.
    Hopefully, they will know some stuff I dont. *which dont take much to be honest* haha!
    Quote Originally Posted by Sterling3316 View Post
    Sent from my DROID RAZR using Tapatalk
    Divin Dave,
    Casey's Avatar
    SW PA
    10,428
    Re: Uneven AG pool
    You will be advised to disassemble the pool and redo the foundation.
    Do NOT attempt to dig out around a full or even half full pool!!!
