Thread: Test numbers and a question
    jandcinok's Avatar
    May 2014
    Jenks, Ok.
    14
    I just did my weekly testing numbers are
    FC 7.5
    CC 0
    Ph 7.8
    TA 140
    CH 180
    CYA 50
    I just added 20 oz. MA (by the way, if you buy Kleenstrip Muriatic Acid, the label doesn't say the strength, on their website in the MSDS is says <25) to bring down the Ph a bit and that will in turn reduce the TA also? Is that correct?
    The calcium hardness is a little low (?) should I even mess with it?
    Since starting with TFP about a month ago, I don't believe my pool has EVER looked this good, and easy to care for, thank you all!
    12 K IG plaster grecian style pool (age unkown, OLD!), Hayward S244T 62GPM sand filter, Hayward 3/4 HP Super Pump, Hayward CL 220 chlorine feeder, Dolphin Deluxe 4 robot cleaner
    38,521
    Re: Test numbers and a question
    Yes the MA will lower the pH and the TA some.
    If you keep the pH above 7.5, then the CH being a little lower should not matter. It will rise as water evaporates and you add top-off water.
    Congrats on taking control
    jandcinok's Avatar
    May 2014
    Jenks, Ok.
    14
    Thanks Jason............when I started TFP my wife didn't understand, it was always......"you're buying MORE bleach?" Now she says, "the pool sure looks nice, I'm going to the store, do you need more bleach?".........LOL
