Results 1 to 9 of 9
Thread: Pool Levels
    Jun 2014
    Monterey Tn
    38
    Pool Levels
    just checked out all the levels
    Ph 7.2
    Ch 130ppm
    Ta 90ppm
    Fc 6ppm
    Cc 4ppm
    Cya ?
    just added chlorine bleach to pool
    On the tester where you check the cya I filled the little tube all the way to the top and the black dot was still there? Not sure what to do, not even sure how to use the PoolMath? Sorry for not being more capable, but I would really like some help please.
    Thanks
    19300 gal (27x54), AG, 22"Millenium Ultimate Granular Filtration w/2HP 2SP Pump,
    July 2013, Polaris 65 Vac, Confer AG Curve Step System, Taylor K-2006 Test Kit, Nordic Sport Hot Tub 300 gal, 78.5"R X35"D
    30,431
    Re: Pool Levels
    What does your water look like?
    Jun 2014
    Monterey Tn
    38
    Re: Pool Levels
    just as clear as can be, its beautiful
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool Levels
    Can you give us some history, Is this just after opening for the spring, or is this a fresh fill, etc?
    Jun 2014
    Monterey Tn
    38
    Re: Pool Levels
    just opened for the season and first time using this method of bleach.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool Levels
    If you don't know your CYA level how are you determining your desired FC level?
    Jun 2014
    Monterey Tn
    38
    Re: Pool Levels
    I'm wasn't then I watched some videos and that helped me a lot.
    38,475
    Re: Pool Levels
    Anyone going to ask about the high CC numbers here? To me that points to needing to SLAM, maybe ammonia? Unless the FAS-DPD was not done correctly.
    Jun 2014
    Monterey Tn
    38
    Re: Pool Levels
    You are correct I don't think I have done the test correctly. After I watched the video about testing I am almost positive I did not do them right.
