Thread: CH levels
    teamstew26's Avatar
    Jun 2014
    Newburgh/NY
    7
    CH levels
    Is it important to add CH to meet my pool heater requirements, even if I do have a vinyl liner?
    14,400 gal vinyl, IG, super II pump , 2 hp, Hayward DE6020 filter, Jandy Pro Series LXI Propane heater, Spill Over Spa, X-Stream Slide
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,023
    Re: CH levels
    If it's brand new and under warranty, yes.
    Otherwise, no. In fact, high CH can cause scale buildup and clog the heat exchanger.
    teamstew26's Avatar
    Jun 2014
    Newburgh/NY
    7
    Re: CH levels
    Thanks Richard!
