Results 1 to 8 of 8
Thread: New Pump + LQ = :-(
    New Pump + LQ = :-(
    Scenario: Right sized with a Hayward Matrix 1 HP 2 Speed. After finally getting the LQ tweaked, I now have flow issues with low speed. Due to slope in yard, the main drain is just below pump level, skimmer, above. If I let the Main Drain be the primary source and back off the skimmer, it will work well, but then the skimmer, well it doesn't skim.
    I recall coming across a couple of threads and the venturi effect just before the pump to aid in flow - would they help in this scenario? Are there any other options?
    My fear is that during a heavy swim load, DW will turn the pump on high, not re-adjust the LQ and over-chlorinate the pool...
    Which those pesky peristaltic pumps were not so $ - starting to understand why folks use them.
    13,500 / AG / Vinyl / Hayward 150 sq ft Cartridge / 1HP 2 Speed / Born in 2009
    Intermatic Timer / Stenner 10GPD + Woods Timer / Former LQ (3/8 upgrade and SMC Valves) 2012
    Re: New Pump + LQ = :-(
    The Liquidator can be setup for any one pump speed, but there is no straightforward way to get it to work correctly at two different pump speeds without adjusting it each time you change pump speed.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Shop around. I got my peristaltic pump for just under 200 with free shipping. I have a variable speed pool pump so the injection rate stays constant with the peristaltic pump.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    I was lucky enough to pick up my peristaltic pump from ebay for $120.00 delivered.... But US Water Systems are having a sale on Stenner pumps at the moment... You can pick one up for $200
    http://www.uswatersystems.com/system...ate-pumps.html
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Thanks all for the input. In looking through some older threads, appears Stenner and RotaChem are the two most common.
    RotaChem seems to have an adjustment that would allow it to come on with the filter (already on timer) and be able to tweak the output.
    The Stenner seems to only have a fixed output.
    Any thoughts on the brand of pump? I know the Stenner with their tank has a rain guard, not sure if the RotaChem can be exposed to the elements - based on what I have been able to fine, it must be protected - never easy.
    Also, what are folks using for the Chlorine Storage Tank?
    Mar 2011
    Florida
    179
    I have my stenner on a separate timer. Car wash near me was selling their 15 gal empty barrels. My run time on the pump is about a half hour a day. 15 min raises chlorine level by 1 for me. My have to increase run time as the pool gets more use over the summer.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    You can also buy Stenner pumps with inbuilt timers.... I think you need to actually look at the website I posted earlier, there's a huge range of Stenner pumps that can do just about anything you'll need.... Have a look....
    I have the Stenner pump and 7 gallon tank.... Its a stand alone unit and it has space in my equipment box next to my filter and my solar pump.... I didn't have anywhere I wanted to install the pump so that's why I chose the Stenner tank.... And because its inside my equipment box (just an outdoor storage box) it won't get wet... Rola-Chem are more expensive than Stenner......
    Thanks all for the input. While spending some time looking at both of those, I stumbled upon a Blackstone pump, made by Hana. Adjustable and a different design, claims less maintenance. Anyone with experience with these?
    The Stenner and matching tank is a nice clean setup.
