Thread: Upgraded to a bigger cartridge, WOW!
    Just thought I'd share my recent experience. I've been using a 3/4 hp pump for the last 2 seasons. My original filter was a hayward 74 sqft cartidge. It was a cheap garage sale find. This year after start up I just couldn't get my head pressure down, it runs 20 psi after cleaning. I picked up a used clear ways filter I believe about 320 sqft on craigslist and installed yesterday. The filters are still a bit dirty, I hosed them down but they could use a good soaking. Head pressure hovers at >5psi now. I have 4 jets that blow and can even run my poorman's deck jets at the same time. Both skimmers flow with eddys inside them and my diver dan cleaner is jetting across the bottom. Its like the pump has twice the flow. I know it makes sense, we cut the resistance to flow considerably, but still I'm amazed at what a difference it makes.
    When the only tool you have is a hammer everything starts looking like a nail.
    Doughboy 16x24 "Aboveground Inground" in progress...
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Upgraded to a bigger cartridge, WOW!
    Good find!
    Just by doubling the size of my filter, I noted a huge increase in flow. I haven't added a pressure gauge to mine yet, because of the type of impeller Intex uses in the smaller pumps (squirrel cage) is high volume low pressure. Still, moves a lot of water.
    Jul 2011
    phoenix
    133
    I had a similar experience this year. I would clean my filters and psi would be at around 18 iirc and after a couple hours would be back up to 28
    I just replaced the filters and tried the pleatco ones due to the significant pric difference compared to the unicell. Like you my skimmer and return lines are working better then ever and I had to turn down the cleaner suction cause it kept going up to the waterline too much grabbing air. If you need to replace your cartridges I would recommend the pleatco one.
    13k IG pebble pool w/waterfall, 1hp whisperflow pump, pentair ccp320 cartridge filter
    Circupool SI45+ swg
    TF100 +speed stir Taylor 1766 salt test
