Results 1 to 9 of 9
Thread: new house new pool
    Oct 2012
    Houston, TX
    29
    new house new pool
    Just moved into new house with bigass pool
    Looks like old owners had pool guy that did little more that add tablets to floating chlorinators. Got it vacummed snd brushed but we have some heavy algae in cracks and crevices and the steps get brownish.
    Got a tf100 kit.
    Fc: 6
    Cc: 0
    Ta: 80
    Ch: 425
    Cya: 80
    Pool store measured cya at 99 last week. But im not sure how absolute the test is for cya. At 100 the black dot is very faint but I can still see it till 80. (Did it 3 times).
    I measured the fc this evening before bed. It was a 4. (The full set of numbers was this am, we had a sunny houston day today). I will measure fc am tomorrow and see what the oovernight fc loss is. I need to get in there and scrub the algea out of the cracks and crevices. And change out The pool and spa lights. What do you guys like for colored led pool bulbs?
    Any way happy to be here and I like the bbb method. Very easy. He re in houston we get 3 121 oz bottles of 8.25 chlorox from sams club for 8.18 plus tax.
    Best y`all...
    Zach
    40,000 gallon ig gunite, Pentair Challanger Century Centurion 2.2 HP Pump, FNS 60 DE filter, Polaris 280, Century Centurion 3/4 HP Booster Pump, Attached ig spa - 1HP Centurion pump - Dual non functioning blowers
    Jun 2013
    Fallsburg, NY
    258
    Re: new house new pool
    Black dot needs to disappear, that means you are above 100, do a 50/50 dilution test to see where you really are. mix 1 part pool water with 1 part tap water and retest the CYA, divide by 2 for your result. For example mix 10ml of pool water with 10ml of tap water and use that water for your CYA test. Let us know the result...
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    If I read correctly, CYA is indeed 80. The black dot didn't disappear at 100, but did disappear at 80, so the level is 80. That is a little high, but can be lived with. If you can I would lower CYA a bit with water replacement, but 80 can be managed.
    With CYA at 80, you want FC between 6 and 11 and never below 6 for normal operation. FC levels should be quite a bit higher, 31, if there is visible algae.
    Oct 2012
    Houston, TX
    29
    Drained about 7 or 8000 gallons got the cya to 65. Then vacuumed and brushed pulled both lights out. Scrubbed inside and out (covered in algae). The put in 10 121 oz bottles of 8.25 chlorox. Will check levels in the am and ensure chlorine is 25-27 range and keep pumps on 24/7....
    Oct 2012
    Houston, TX
    29
    Checked FC last night was 24 and cc at 0.5(not convinced of that, but wife says she saw it turn pink )
    Anyhow... tested this AM before direct sun and had 19ppm FC and 0 CC. Dropped in 4 more gallons of 8.25 chlorox and brushed the sides and turned on the polaris for the day... should bring to 28 ppm(per pool pal app)
    gotta buy more bleach....
    Oct 2012
    Houston, TX
    29
    This evening checked chlorine... down to 14..... 6 more gallons..... this is a ton of bleach....
    Jul 2013
    Gilbert, Az
    116
    Yeah this process takes a lot of bleach.. but once you get through with this part it goes WAY down
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    Oct 2012
    Houston, TX
    29
    good news... FC was 25 this AM and only took one bottle... looks like we are making progress!!!
    Oct 2012
    Houston, TX
    29
    Chlorine loss for the day yesterday was huge, down to 14. Pumped it up to 26 last night. Has 0 fc loss overnight.
    Dosed with 6 more bottles this am to be sure to kill any possible mustard algae, taking fc to 40. Dumped in all my hoses and equiptment.....
    I assume I have to keep the mustard shock for 24 hours?
    Also do the higher the levels of chlorine during the day the more you lose since there is more to be oxidized?
    Thx
