Thread: Wire terminal
    Sep 2013
    DFW Metroplex
    119
    Wire terminal
    My EcoTech Ez 1.5 HP motor should be here end of next week, collecting all the necessary information, does anyone know what type of wire terminal to use for this?
    [IMG][/IMG]
    From youtube video I saw something like below and I don't know what type of terminals hots are connected to.
    [IMG][/IMG]
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Wire terminal
    If the spade terminals are there, you see where they plug in. If the wire doesn't have them preinstalled, you loosen the screws and slip the stripped wire under the washer, in that groove they molded in, and tighten it all down. White is silver, black is gold.
    Sep 2013
    DFW Metroplex
    119
    Re: Wire terminal
    Thanks Richard, I appreciate it.
