Results 1 to 11 of 11
Thread: Dirty Pool Liner
    Jul 2011
    Corinth, NY
    76
    Dirty Pool Liner
    Hello. For some reason my pool lost almost all of it's water during the winter months. There was 1/4 of water left in the pool. I don't think there is a hole in the liner so why would the water be so low? Also, the bottom of the liner is very dirty so I am now empting the rest of the water and the I have to clean the liner. What is the best cleaning solution to use to clean a liner? Thanks for your help.
    Mark
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    Re: Dirty Poll Liner
    I'm a little confused. Your signature says you have a fiberglass pool but the question is about a liner?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jul 2011
    Corinth, NY
    76
    I have tried to change my signature but I don't know how to do it. I never wrote that signature.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,086
    mkdsk101,
    I have sent you a PM on this issue and corrected your signature. To add a new signature go to................
    Settings > Edit Signature
    Jul 2011
    Corinth, NY
    76
    Fixed the signature but what about an answer to my question if anyone can help me.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The water had to get out somewhere. Inspect right at the level where it drained to. It's gotta be a hole there somewhere.
    Isolated Spa - 345 Gallons
    Jul 2011
    Corinth, NY
    76
    Did inspect the entire liner and there are no holes at all. Do winter pool covers seep water through them at all? What is the best cleaning solution to use on a liner?
    I used the pool the summer of 2013 and then covered it for the winter and then opened it up today and the water was very low.
    Feb 2014
    Central Minnesota
    5,080
    I can't comment on cleaning a liner. No experience on that for me. If you have a safety winter cover, they certainly allow liquid water (and snow that melts on to).
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,869
    I have no experience with above ground pools and their liners. If it is anything like an inground, the important thing to do is fill it and balence the water, run filter....brush.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Dirty Pool Liner
    If it is algae that caused the staining, perhaps a good SLAM would cure it. Along with vacuuming, etc.
    Jul 2011
    Corinth, NY
    76
    Found out from my neighbor that his pool was also low in water when he opened it. It was from the heavy snow and ice we had this year and it pushed the water up and out of the filter inlets.
