Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Pump replacement help needed
    Dec 2012
    Groves, Texas
    38
    I currently have a Hayward super 2 pump with a ao smith b809 2 hp motor on it. I would like to replace the motor with a 2 speed motor. The pool is 26000 gallons. Do I need a 2 hp motor or can I downsize? Can anyone point me to the correct motor.
    Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump replacement help needed
    Downsizing might be possible but it depends your setup.
    Do you have a spa, water fall or any other high flow water feature?
    If not, then yes, you could probably downsize but you would need to downsize both the motor and impeller.
    Mark
    Dec 2012
    Groves, Texas
    38
    I have a waterfall but it is on a separate pump. Any idea on what motor I could go with. If I stay with a 2 hp would the ao smith b2979. Would this work? Also what timer would I need?
    mas985's Avatar
    Pleasanton, CA
    11,737
    It depends. What is the service factor of the old motor? Super II comes in both full and up rated versions. Also, what voltage is it currently wired for?
    Mark
    Dec 2012
    Groves, Texas
    38
    Service factor was 1.25 full rated. Could I put an ecotech 1.5 in?
    mas985's Avatar
    Pleasanton, CA
    11,737
    EcoTech 1.5 in. ? Or did you mean a 1.5 HP. You could if you down size the impeller for the appropriate THP (service factor * HP).
    Mark
    Sep 2013
    DFW Metroplex
    119
    I ordered an Ecotech 1.5 EZ last Friday from Hydro pool, it has 1.6 service factor (2.4 THP), I am also replacing my 2 HP single speed motor. I calculated my return of investment with mas985 worksheet, I should get mine in 13 to 14 months.
    13K gal, IG, Gunite pool with raised spa water spill over to pool, built on 2005
    1.5 HP Hayward MaxFlo VS - June 2014
    DE Filter Model # DE6020
    Added Borates on Jun 2014
    Dec 2012
    Groves, Texas
    38
    Yes I meant 1.5 hp? Would this be a good choice over a 2 speed. I would not have to buy another timer if I went this route.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Time will tell on the reliability of the motor but for any VS, if you live in an area with lightning, you should probably add surge protection to protect your investment.
    Mark
    Dec 2012
    Groves, Texas
    38
    Thanks. What else will I need to replace? I will order the motor, 1.5 hp impeller, and seal kit. Anything I am missing?
    mas985's Avatar
    Pleasanton, CA
    11,737
    That should do it, just make sure that you get the 56J version of the EZ. Also, I think you could use the 1.5 EZ with your current impeller if you never run it at full speed. The HP ratings are so close that it shouldn't be an issue. Just limit the RPM to 3400 and you should be fine. Plus the controller has overload protection.
    Mark
    Sep 2013
    DFW Metroplex
    119
    Quote Originally Posted by mas985 View Post
    I already have a whole house surge protector installed near my main breaker, is that sufficient?
    mas985's Avatar
    Pleasanton, CA
    11,737
    It should if it has lightning protection. But you should make sure that the pool service panel actually goes through the SP. It isn't a given.
    Mark
    Sep 2013
    DFW Metroplex
    119
    Thanks Mark, any simple 2 in 1 device for outdoor use? (protect against lightning and surge)
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    Dec 2012
    Groves, Texas
    38
    I am going to get the ecotech. Should I get the 3 hp or the 1.5 hp. They are about the same price.
    Thanks
    Sep 2013
    DFW Metroplex
    119
    Quote Originally Posted by bags23 View Post
    Thanks
    I went with 1.5 hp for $329 from hydropool, if the price is close enough yeah 3 HP is good option in my opinion, which store you are looking at?
    Thank you
    Dec 2012
    Groves, Texas
    38
    1stoppoolsupply.com has the 3hp for $351 plus about $40 shipping. I already ordered the 1.5 hp but could return it if the 3 hp is worth the extra $.
    Dec 2012
    Groves, Texas
    38
    Any help is greatly appreciated. Should I get the 3 hp or the 1.5 hp? If the pump is going to be run at the lower rates does it really matter?
    Thanks
  20. Back To Top    #20
    mas985's Avatar
    Pleasanton, CA
    11,737
    I can only repeat what I posted before. I am not sure what other information you might need. If it has shipped already, there is no reason to return it.
    Mark
