Thread: Question on Calcium Hardness with New Plaster Startup
    May 2014
    Houston, TX
    5
    I had my pool replastered about two weeks ago (May 24). The CH level has varied from 200 to 250 the last two weeks. Today it was 250.
    The plaster contractor gave me startup procedures from the National Plasterers Council (NPC). These procedures say the following: "After the 4th Day-calcium levels should be adjusted slowly over the 28 day period not to exceed 200 ppm." Am I OK to keep the level at 225-250 ppm or do I need to strictly follow the NPC levels? I hate to have to pump water out of the pool already to lower CH after just filling it up.
    Thanks, Tom
    16500 gal IG gunite/white plaster
    DE filter TF-100 Test Kit
    Now using bleach
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Question on Calcium Hardness with New Plaster Startup
    I would say talk to your contractor as this may be a warranty coverage issue
    The way I read their instructions, you shouldn't raise CH when it is already 200 or higher. But if it goes higher on it's own that is normally fine. It is not completely clear if that is what they meant or not, but it is the only possibility I can think of that makes any sense.
