Thread: FC Target level
    May 2014
    Virginia Beach, VA
    56
    FC Target level
    Ok, since my pool is in the bright sunshine 12hrs a day, I'm thinking I should probably adjust my "target" FC level.
    The goal range for my pool size with CYA @ 40 is 3-7ppm. I've been using a 5 for my target. I test and add my FC around 8pm, once the sun is pretty much off the pool, this way the pool can start the next day with the FC ready for combat while we're at work.
    But, usually when I test it around 8pm, the FC is around 2ppm...I'd prefer it to be higher.
    Do yall think I should adjust my "target" FC level to 7 vs 5 to hopefully allow my FC level to be higher when I test it at 8pm?
    I'd rather not raise my CYA above 40.
    24' Round Above Ground - 13,500 gal, Cartridge Filter, Installed on 5-7-14, First Time Pool Owner! TFP True Believer!
    38,275
    Re: FC Target level
    The key is the MINIMUM. Target whatever is required to keep the FC above the Min at all times. You might should increase the CYA to 50ppm, not sure why you don't want to as it will likely reduce the amount of FC you have to add each day.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: FC Target level
    If you target 5 and end at 2, target 6 and hopefully end at 3. Note that warm weather means more swimmers means more chlorine usage.
    We could keep the chemistry perfect if people would just stop using the pool!
    May 2014
    Virginia Beach, VA
    56
    Re: FC Target level
    Thanks. The reason I didn't want to raise my CYA to 50 is because I'm trying to keep a little buffer incase I consider dropping a puck during a vacation time period since none would be around to add bleach daily...unless I could just raise the FC to shock level and covering the pool with pump off and have that suffice.
    I just fear getting that CYA to high and then looking at water replacement.
