Thread: Backwashing to Drain the Pool
    Real time help appreciated-
    I have a plunger valve going into a DE filter on my 35K gallon pool. The only way I have to pump water to waste is to pull the plunger valve and backwash the filter to waste. Can I backwash to waste for a few hours to drain the pool to accommodate a partial refill to lower my CYA? Should I remove the DE grids or does it matter?
    Assuming this is safe I'm going to start a drain/refill this afternoon. Going to use the main drain and a vacuum hose with the understanding that once I start draining I can't stop because I can't let the pump loose prime.
    If it's not safe I'm going back to the drawing board... can remove the plunger and use a few of these to stop up the plumbing in the right places?http://www.homedepot.com/p/Oatey-2-i...3401/100346775
    Trying to avoid a sump pump. The pool is going to be remodeled this fall and I'm going to make sure I have the ability to vacuum/pump to waste on the new pluming design.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Backwashing to Drain the Pool
    Pull the grids and it will work. Run backwash for hours and any debris in the pool will end up embedded on the insides of the grids and ruin them.
    Thank you
    Just a follow-up to anyone searching for info. Backwashing to drain the pool seemed to work okay. The pressure on the system was about 28 PSI while draining when my normal clean filter PSI generally runs at about 12 PSI. I haven't put the grids back into the filter- waiting for it to stop raining. The pool should be filled by mid afternoon and I'll get it started up.
    Make sure you tighten the band clamp on the filter really well. Mine popped off at one point. Fortunately the water level wasn't so low that I couldn't regain the prime on the pump, but it was close.
    I'll post water test results in the other forum tonight.
    30,403
    Richard320 brings up a VERY good point. backwashing is a little tough on either sand or DE so it is generally not a good idea to do it for hours. A longer than normal backwash is just fine but doing it as an everyday practice is not helpful.
