Thread: Coping crack need repair?
    Sep 2007
    Midwest
    330
    When they built my pool last year they were landscaping and the bobcat ran into the deck. It cracked the perimeter a little so they came out and patched it up. I just noticed that in the location of the incident there is a hairline crack across the deck. It appears to be through the full thickness but doesn't involve the pool shell. Does this need to be addressed, sealed or repaired? Here are some pics. The first 3 pics are for perspective as I pan into the hairline crack.
    Dave
    Our pool-
    20x40 Free Form Gunite (3'-8'), 26,000 G, AutoPilot Salt Chlorine Generator SC-48, Aqua blue pebble sheen, Textured Sundek, Pentair Easy touch with remote control, 1hp Sta-Rite Max-E-Pro pump, Max-E- Therm heater 333k BTU, System 3 Mod Media Cartridge filter, and Polaris 380 cleaner with booster pump
    Sep 2007
    Midwest
    330
    Re: Deck crack need repair?
    Bump. Anybody have a suggestion.....please
    Dave
    Our pool-
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    Is that deck or coping where the crack is? If the crack does not extend into the pool, it would seem safe to leave. I do not know how this would be fixed cosmittically.
    Sorry,
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    Sep 2007
    Midwest
    330
    Oops...yes coping. Cosmetically you really can't see it unless you look for it. I was actually kinda concerned that with the freeze/thaw cycles we have here in the midwest that if I didn't seal it or something that it might erode or crack worse
    Dave
    Our pool-
