Results 1 to 12 of 12
Thread: Leslie's pH Lock
    Jun 2012
    Howell, NJ
    977
    Leslie's pH Lock
    I was looking for CYA on Leslie's website to compare prices with the other local stores (they are EXPENSIVE) and I came across this so-called pH Lock. I can't see what chemicals are in it, so I don't know what it is. Has anyone heard of this before? I'm not going to use it, just wondering if anyone can shed some light on this "magical potion." http://www.lesliespool.com/leslies-1...1-qt/14125.htm
    According to their website, "pH Lock will instantly lower or raise the pH to the correct range of 7.2 to 7.8"
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Re: Leslie's pH Lock
    It is a phosphate buffer. It doesn't exactly "lock" in the PH, but it can help make it more stable. On the other hand it can cause a lot of trouble if you have calcium in the water as well, as phosphate and calcium can precipitate out together and make a mess.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,570
    I couldn't find an MSDS sheet on it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Another product I wouldn't want in my pool.
    Just curious, how much of what would be considered industrial waste is being packaged and sold through pool stores?
    Richard320's Avatar
    Jan 2010
    18,967
    I see a real value in it, actually, from the pool store angle. Sell them this to raise phosphates, and then....
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    True that!!
    Jun 2012
    Howell, NJ
    977
    So according to their website, I would need about $430 worth of this product for my pool. 1 quart treats 500 gallons, and my pool is about 13,500 gallons. I would need 27 quarts, times $15.99 a quart. Think they would give me a bulk purchase discount? Do people seriously pay over $400 for just 1 chemical?
    Maybe this "potion" is only intended for spas, because down on the page, it says "Adjusts pH level as required to balance spa water in 7.2 to 7.8 range. " They don't mention pools.
    John
    Apr 2010
    East Texas
    9,570
    It's target market is spa owners, not pools.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Even at that, it's a rather expensive product.
    My guess is the marketing department is feeding on the erroneous belief that the more expensive the product, the better it is.
    Jan 2012
    'burbs of Augusta, Georgia
    7,266
    It sounds like Robarb's pH Perfect product meant for spas
    I believe they are exactly the same, certainly at least very similar.
